Track and visualize daily moods with GPT-4o, Wolfram Alpha, Sheets, and Slack
Created by: koichi nagino || nagi
koichi nagino
Last update a month ago
Overview
This workflow, "Mood Graph Studio," offers a comprehensive solution to track and visualize your emotional well-being. By simply inputting a single sentence about your mood, this template uses AI to perform a sentiment analysis, generates a visual graph via Wolfram Alpha, provides personalized feedback, and logs everything to Google Sheets.
It is designed for anyone interested in mindfulness, self-reflection, or quantified self-tracking.
How It Works
The workflow is divided into two main API functionalities and a manual trigger for easy testing.
  1. Analyze a Single Mood (/mood endpoint)
  • An AI Agent (OpenAI) quantifies your mood text into valence (positivity) and energy (activity).
  • A query is sent to Wolfram Alpha to generate a simple linear graph based on the score.
  • A second AI Agent provides short, encouraging advice in Japanese.
  • The complete entry is logged as a new row in Google Sheets.
  • Returns a JSON response containing the full analysis and the graph image.
  1. Generate Mood History Graph (/history endpoint)
  • Retrieves historical mood data for a specified user from Google Sheets.
  • A Code node formats the data into a time-series plot query.
  • Wolfram Alpha generates a line graph visualizing the mood trend over time.
  • The resulting graph is automatically posted to Slack.
How to Set Up
1. Credentials
You must add your own credentials for the following services in the respective nodes:
  • OpenAI: Used in both Chat Model nodes.
  • Google Sheets: Used in the "Log Mood" and "Get History" nodes.
  • Slack: Used in the "Send History" node.
2. Wolfram Alpha App ID
This workflow uses the HTTP Request node to call the Wolfram Alpha API.
3. Google Sheet Configuration
  • Create a new Google Sheet.
  • Paste the Sheet ID into the Document ID field in both Google Sheets nodes.
  • Crucially, ensure the first row has the following headers exactly (case-sensitive):
    userId, moodText, valence, energy, createdAt, wolframQuery, feedback
How to Use
For Testing:
Use the Manual Trigger. Modify the sample text in the "Set Test Data" node and click "Execute Workflow" on the canvas.
For Production:
Activate the workflow. Send POST requests to the Production URL of the Webhook nodes.
