Monitor & respond to Google Maps reviews using AI, Apify, Slack, and Sheets
Created by: takuma || takuma
takuma
Last update a month ago
This workflow automates reputation management for physical stores (restaurants, retail, clinics) by monitoring Google Maps reviews, analyzing them with AI, and drafting professional replies.
It acts as a 24/7 customer support assistant, ensuring you never miss a negative review and saving hours of manual writing time.
Who is this for?
  • Store Managers & Owners: Keep track of customer sentiment without manually checking Google Maps every day.
  • Marketing Agencies: Automate local SEO reporting and response drafting for multiple clients.
  • Customer Support Teams: Get instant alerts for negative feedback to resolve issues quickly.
  1. Schedule: Runs every 24 hours (customizable) to fetch the latest data.
  2. Scrape: Uses Apify to retrieve the latest reviews from a specific Google Maps URL.
  3. Filter: Checks the Google Sheet database to identify only new reviews and avoid duplicates.
  4. AI Analysis: An AI Agent (via OpenRouter/OpenAI) analyzes the review text to:
    • Generate a short summary.
    • Draft a polite, context-aware reply based on the star rating (e.g., apologies for low stars, gratitude for high stars).
  5. Alert: Sends a Slack notification.
    • Low Rating (<4 stars): Alerts a specific channel (e.g., #customer-support) with a warning.
    • High Rating: Alerts a general channel (e.g., #wins) to celebrate.
  6. Save: Appends the review details, AI summary, and draft reply to the Google Sheet.
Requirements
  • n8n: Cloud or self-hosted (v1.0+).
  • Apify Account: To run the Google Maps Reviews Scraper.
  • Google Cloud Platform: Enabled Google Sheets API.
  • Slack Workspace: A webhook URL or OAuth connection.
  • OpenRouter (or OpenAI) API Key: For the LLM generation.
How to set up
  1. Google Sheets: Create a new sheet with the following headers in the first row:
    reviewId, publishedAt, reviewerName, stars, text, ai_summary, ai_reply, reviewUrl, output, publishedAt date.
  2. Configure Credentials: Set up your accounts for Google Sheets, Apify, Slack, and OpenRouter within n8n.
  3. Edit the "CONFIG" Node:
    • MAPS_URL: Paste the full Google Maps link to your store.
    • SHEET_ID: Paste the ID found in your Google Sheet URL.
    • SHOP_NAME: Your store's name.
  4. Slack Nodes: Select the appropriate channels for positive and negative alerts.
How to customize
  • Change the AI Persona: Open the AI Agent node and modify the "System Message" to match your brand's tone of voice (e.g., casual, formal, or witty).
  • Adjust Alert Thresholds: Edit the If Rating < 4 node to change the criteria for what constitutes a "negative" review (e.g., strictly < 3 stars).
  • Multi-Store Support: You can loop this workflow over a list of URLs to manage multiple locations in a single execution.
