Analyze food ingredients from Telegram photos using Gemini and Airtable
Created by: Ehsan || ehsan-z
Ehsan
Last update 16 days ago
🛡️ Personal Ingredient Bodyguard
Turn your Telegram bot into an intelligent food safety scanner. This workflow analyzes photos of ingredient labels sent via Telegram, extracts the text using AI, and cross-references it against your personal database of "Good" and "Bad" ingredients in Airtable.
It solves the problem of manually reading tiny, complex labels for allergies or dietary restrictions. Whether you are Vegan, Halal, allergic to nuts, or just avoiding specific additives, this workflow acts as a strict, personalized bodyguard for your diet. It even features a customizable "Persona" (like a Sarcastic Bodyguard) to make safety checks fun.
🎯 Who is it for?
  • People with specific dietary restrictions (Vegan, Gluten-free, Keto).
  • Individuals with food allergies (Nuts, Dairy, Shellfish).
  • Special dietary observers (Halal, Kosher).
  • Health-conscious shoppers avoiding specific additives (e.g., E120, Aspartame).
🚀 How it works
  1. Trigger: You send a photo of a product label to your Telegram Bot.
  2. Fetch Rules: The workflow retrieves your active "Watchlist" (Ingredients to avoid/prefer) and "Persona" settings from Airtable.
  3. Vision & Logic: It uses an AI Vision model to extract text from the image (OCR) and Google Gemini to analyze the text against your strict veto rules (e.g., "Safe" only if ZERO bad items are found).
  4. Response: The bot replies instantly on Telegram with a Safe/Unsafe verdict, highlighting detected ingredients using HTML formatting.
  5. Log: The result is saved back to Airtable for your records.
⚙️ How to set up
This workflow relies on a specific Airtable structure to function as the "Brain."
  1. Set up Airtable
  2. Set up Telegram
    • Message @BotFather on Telegram to create a new bot and get your API Token.
    • Add your Telegram credentials in n8n.
  3. Configure AI
    • Add your Google Gemini API credentials.
    • Note on OCR: This template is configured to use a local LLM for OCR to save costs (via the OpenAI-compatible node). If you do not have a local model running, simply swap the "OpenAI Chat Model" node for a standard GPT-4o or Gemini Vision node.
📋 Requirements
  • n8n (Cloud or Self-hosted)
  • Airtable account (Free tier works)
  • Telegram account
  • Google Gemini API Key
  • Local LLM (Optional, for free OCR) OR OpenAI/Gemini Key (for standard Cloud Vision)
🎨 How to customize
  • Change the Persona: Go to the "Preferences" table in Airtable to change the bot's personality (e.g., "Helpful Nutritionist") and output language.
  • Update Ingredients: Add or remove items in the "Watchlist" table. Mark them as "Good Stuff" or "Bad Stuff" and set Status to "Active".
  • Adjust Sensitivity: The AI prompt in the "AI Agent" node is set to strict "Veto" mode (Bad overrides Good). You can modify the system prompt to change this logic.
⚠️ Disclaimer
This tool is for informational purposes only.
  1. Not Medical Advice: Do not rely on this for life-threatening allergies.
  2. AI Limitations: OCR can misread text, and AI can hallucinate.
  3. Verify: Always double-check the physical product label.
Use at your own risk.
