Process images with VLM run: Auto segmentation & detection with Drive-Telegram sharing
Created by: Mehedi Ahamed || mehedi
Mehedi Ahamed
Last update a month ago
This workflow automates image processing using VLM Run, extracting signed URLs, downloading results, and distributing them via multiple channels (Google Drive & Telegram).
✅ Key Features
  • Upload image files through a Form Trigger.
  • Process images through two VLM Run agents simultaneously:
    • Segmentation Agent → extracts objects.
    • Detection Agent → generates bounding boxes.
  • Webhooks capture completed results asynchronously.
  • Code Node extracts the full signed URL for secure downloading.
  • Downloaded images are automatically:
    • Uploaded to Google Drive
    • Sent to a Telegram chat
⚙️ Workflow Flow
  1. User Uploads File → Form Trigger node
  2. VLM Run Agents → Segmentation & Detection agents
  3. Webhook Nodes → Receive processed results
  4. Code Node → Extract signed URLs
  5. Download Node → Retrieve processed images
  6. Distribution Nodes → Upload to Google Drive & Telegram
📌 Notes
  • Ensure Google Drive OAuth2 credentials have upload permissions.
  • Telegram Bot token and chat ID must be configured correctly.
  • Regex in the Code Node is critical for capturing full signed URLs including query parameters.
  • Workflow allows multi-channel sharing of images automatically.
⚠️ Community Node Disclaimer
This workflow uses VLM Run node
