Generate LinkedIn posts using Telegram, Supabase vector DB and OpenAI RAG
Last update a month ago
Overview
AI-powered n8n workflow that creates viral LinkedIn posts by learning from successful content. Features two modules: (1) Telegram-based scraper that builds a vector database of viral LinkedIn posts, and (2) Web form that generates optimized posts using multi-agent AI with RAG (Retrieval-Augmented Generation) from your curated viral content library.
Key Capabilities:
  • Scrapes LinkedIn post content via Telegram bot
  • Stores posts in Supabase vector database with OpenAI embeddings
  • 3-agent system analyzes hooks, structures outlines, and generates posts
  • RAG integration retrieves similar viral posts for pattern matching
  • Auto-publishes to LinkedIn or provides formatted output
How It Works
Module 1: Viral Post Collection (Telegram Bot)
Step 1: URL Validation
  • User sends LinkedIn post URL to Telegram bot
  • Workflow validates URL contains "linkedin.com"
  • Shows typing indicator for better UX
Step 2: Content Scraping
  • HTTP request fetches post HTML
  • CSS selector extracts main commentary: [data-test-id="main-feed-activity-card__commentary"]
  • Handles scraping failures with error messages
Step 3: Vector Storage
  • Converts post text to OpenAI embeddings (text-embedding-ada-002)
  • Stores in Supabase linkedin_post table with vector indexing
  • Sends success confirmation via Telegram
Module 2: AI Post Generation (Web Form)
Stage 1: Hook Analysis Agent
  • Input: User-provided hook text
  • Process: AI extracts topic, niche/industry, emotional tone, and 3-5 key points
  • Output: Structured JSON with analyzed elements
  • Models: GPT-4o-mini or Gemini 2.5-flash (dual fallback)
Stage 2: Post Structure Agent
  • Input: Analyzed hook data
  • Process: Creates 5-section outline (Hook, Problem, Value/Lesson, Solution, CTA)
  • Output: Structured framework for final post
Stage 3: Post Generator Agent (RAG)
  • Input: Post structure + topic
  • RAG Process:
    • Queries Supabase vector store for 5 most similar viral posts
    • Analyzes patterns: hooks, storytelling, CTAs, engagement metrics
    • Identifies optimal length, formatting, and emotional triggers
  • Output: Complete LinkedIn post applying viral patterns
  • Models: GPT-4o-mini or Gemini 2.5-flash with GPT-5-NANO for structured output
Stage 4: Publication
  • Auto-publishes to LinkedIn via API
  • Or returns formatted post text for manual posting
How To Use
1. Configure Supabase Vector Database
  • Create Supabase project
  • Create table: linkedin_post with vector column (1536 dimensions for OpenAI embeddings)
  • Enable vector extension: CREATE EXTENSION vector;
  • Update credentials in "Upload Document" and "Supabase Vector Store" nodes
2. Set Up Telegram Bot (Module 1)
  • Create bot via @BotFather
  • Get bot token and update "On Telegram Message" credentials
  • Start bot and get your chat ID
  • Activate workflow
3. Configure OpenAI API
  • Add API key to "Embeddings" nodes (both modules)
  • Configure language model credentials (GPT-4o-mini, GPT-5-NANO)
4. Set Up LinkedIn API (Optional for Module 2)
  • Create LinkedIn app with member permissions
  • Configure OAuth2 credentials in "Create a post" node
  • Or remove node to get text output only
5. Access Web Form
  • Get form URL from "LinkedIn Form" webhook
  • Bookmark for easy access
