Generate article-based posts for LinkedIn, Twitter (X), and Reddit with OpenAI
Last update a month ago
Overview
AI-powered workflow that transforms any article URL into platform-optimized social media posts for LinkedIn, Twitter (X), and Reddit. Uses Mozilla Readability for content extraction, multi-agent AI with RAG from viral LinkedIn post database, and interactive review forms for content refinement before auto-publishing.
Key Capabilities:
  • Extracts article content: title, author, text, images, metadata
  • Generates LinkedIn posts using 3-agent system with viral pattern matching
  • Creates Twitter threads under 280 characters with article links
  • Auto-posts to Reddit with AI-selected flairs
  • Interactive review/regeneration workflow with feedback loops
  • Auto-publishes with images or links to all platforms
How It Works
Stage 1: Article Content Extraction
  1. Form Submission: User enters article URL (with basic auth protection)
  2. URL Validation: Checks if valid URL format
  3. Article Scraping: HTTP request fetches HTML content
  4. Readability Parsing: Mozilla Readability extracts:
    • Clean article text (removes ads, navigation, etc.)
    • Title, author, excerpt
    • Word count, site name
    • Featured image (from og:image, twitter:image, or first img tag)
  5. Error Handling: Returns user-friendly error if scraping fails
Stage 2: LinkedIn Post Generation (3-Agent System)
Agent 1: LinkedIn Post Strategist
  • Input: Extracted article content (title, text, author, excerpt)
  • RAG Process: Queries Supabase vector database for similar viral LinkedIn posts
  • Analysis: Identifies patterns, hooks, formatting, engagement triggers
  • Output: Strategic insights and viral content patterns
Agent 2: LinkedIn Post Generator
  • Input: Article content + strategist insights
  • Process: Creates post using viral patterns from database
  • Rule: Must include article URL in post
  • Output: Draft LinkedIn post
Agent 3: LinkedIn Post Formatter
  • Input: Generated post
  • Process:
    • Removes extraneous content
    • Applies Sans Serif Bold Unicode for emphasis (𝗯𝗼𝗹𝗱 𝘁𝗲𝘅𝘁)
    • Removes markdown/em dashes
    • Ensures clean formatting
  • Output: Polished, ready-to-post LinkedIn content
Review Loop:
  1. User sees formatted post in web form
  2. Options: "Regenerate" or "Continue"
  3. If regenerate: Provide feedback → Agent creates new version
  4. Second review form with same options
  5. After 2 iterations or approval, proceeds to image selection
Stage 3: Image Handling for LinkedIn
  1. Image Preview: Shows extracted article image
  2. User Choice:
    • "Yes" → Downloads image, posts with text + image
    • "Continue without Image" → Posts with text + article link preview
  3. Auto-Publish: Posts to LinkedIn with selected format
Stage 4: Twitter (X) Post Generation
Parallel process (runs alongside LinkedIn):
  1. Twitter Agent:
    • Creates tweet under 280 characters (including spaces)
    • Must include article URL
    • Uses GPT-4.1 or GPT-5 models
  2. Tweet Review Form: User reviews generated tweet
  3. Regeneration Loop (if requested):
    • User provides feedback
    • Re-generate Tweet Agent creates new version
    • Second review form
  4. Auto-Tweet: Posts with article image attachment
Stage 5: Reddit Post Automation
Parallel process (runs alongside LinkedIn/Twitter):
  1. Subreddit Selection: User picks from dropdown (r/n8n, r/mcp, r/technews)
  2. Flair Retrieval: Fetches available flairs for selected subreddit via Reddit API
  3. AI Flair Selection:
    • GPT-4o-mini analyzes article title + available flairs
    • Selects most appropriate flair
  4. Auto-Post: Submits link post to Reddit with title and selected flair
How To Use
Prerequisites
API Credentials Required
  1. OpenAI API: GPT-4.1, GPT-5, GPT-5-mini, GPT-4o-mini access
  2. Supabase: Vector database with linkedin_post table (from previous workflow)
  3. LinkedIn OAuth2: Developer app with posting permissions
  4. Twitter OAuth2: Developer account with tweet permissions
  5. Reddit OAuth2: App credentials with submit permissions
  6. Basic Auth: For form password protection
Setup Steps
1. Configure Form Access
  • Open "On Article Submission" node
  • Set up basic auth credentials for form protection
  • Get form URL from webhook settings
2. Link Vector Database
  • Ensure Supabase vector store has viral LinkedIn posts (use previous workflow to populate)
  • Verify "LinkedIn Post Vector Store" credentials
  • Check "Embedding" node has OpenAI API key
3. Set Up Social Media APIs
LinkedIn:
  • Configure "Text + Image" and "Text + Link" nodes
  • Update person parameter with your LinkedIn profile ID
  • Add OAuth2 credentials
Twitter:
  • Configure "Tweet" and "Re-generated Tweet" nodes
  • Add Twitter OAuth2 credentials
Reddit:
  • Update subreddit list in "Reddit Form" dropdown (customize to your subreddits)
  • Configure "Get Flair", "Reddit Post" nodes with OAuth2
  • Update subreddit name in "Reddit Post" query parameters
4. Configure AI Models
  • Verify all OpenAI credentials in language model nodes
  • Models used: GPT-4.1, GPT-5, GPT-5-mini (adjust based on your access)
