Lead scoring & auto-assignment with GPT-4 and GoHighLevel + Slack alerts
Created by: Țugui Dragoș || tuguidragos
Țugui Dragoș
Last update a month ago
This workflow automatically scores and categorizes new GoHighLevel contacts using AI (GPT-4), then tags and assigns them to the appropriate team member based on their score. Hot leads also trigger a Slack notification for immediate follow-up.
What does it do?
  • Triggers when a new contact is added in GoHighLevel.
  • Fetches full contact details and recent engagement data.
  • Uses AI (GPT-4) to analyze and score the lead (1-100), categorize it (Hot, Warm, Cold), and provide an explanation.
  • Tags the contact in GoHighLevel based on the score.
  • Assigns the lead to the correct sales or nurturing team member.
  • Sends a Slack alert for Hot leads to ensure fast response.
Use case
Use this workflow to automate lead qualification and assignment in sales teams using GoHighLevel. It helps prioritize high-quality leads, ensures fast follow-up, and reduces manual work.
How to configure
  1. GoHighLevel API:
    • Set your GoHighLevel API URL and API key in the Workflow Configuration node.
    • Update user IDs for assignment as needed.
  2. Slack Integration:
    • Add your Slack webhook URL or credentials in the Slack Notify Hot Lead node.
  3. AI Provider:
    • Configure your OpenAI (or compatible) credentials in the AI Lead Scoring (GPT-4) node.
  4. Adjust thresholds:
    • If needed, change the score thresholds in the IF nodes to match your business logic.
  5. Activate the workflow:
    • Once configured, activate the workflow to start processing new leads automatically.
Tip:
You can further customize the workflow to fit your sales process, add more notifications, or integrate with other tools as needed.
