Create AI dream videos with analysis using Veo3 and Telegram
Created by: 福壽一貴 || fukujukazuki
福壽一貴
Last update 23 days ago
Who is this for?
  • Dream journaling enthusiasts who want to visualize and record their dreams
  • Self-improvement practitioners interested in dream analysis and psychology
  • Content creators looking for unique, AI-generated dream-based content
  • Wellness coaches and therapists who use dream work with clients
What it does
  1. Receives dream descriptions via Telegram bot commands
  2. Parses visual style selection from 8 options (cinematic, ghibli, surreal, vintage, horror, abstract, watercolor, cyberpunk)
  3. Analyzes the dream using AI to extract themes, symbols, and psychological meaning
  4. Generates optimized video prompt tailored to the selected style with audio descriptions
  5. Creates AI video with native audio using Google Veo3 (single API call)
  6. Logs to Google Sheets as a searchable dream journal
  7. Sends video + analysis back to user via Telegram
How to set up
Estimated setup time: 15 minutes
Step 1: Create Telegram Bot
  1. Message @BotFather on Telegram
  2. Send /newbot and follow prompts
  3. Copy the API token
Step 2: Get fal.ai API Key
  1. Sign up at fal.ai
  2. Generate API key from dashboard
  3. In n8n, create Header Auth credential:
    • Name: Authorization
    • Value: Key YOUR_FAL_API_KEY
Step 3: Get OpenRouter API Key
  1. Sign up at openrouter.ai
  2. Generate API key
  3. Add to n8n as OpenRouter credential
Step 4: Set up Google Sheets (Optional)
  1. Create new spreadsheet with columns: Timestamp, Username, Style, Dream, Theme, Emotion, Type, Meaning, Video URL
  2. Connect Google Sheets credential in n8n
  3. Select your document and sheet in the "Log to Google Sheets" node
Step 5: Connect Credentials
  1. Add Telegram credential to all Telegram nodes
  2. Add fal.ai Header Auth to both HTTP Request nodes
  3. Add OpenRouter credential to the LLM node
Requirements
Service Purpose Cost
Telegram Bot User interface Free
fal.ai (Veo3) Video + audio generation ~$0.10-0.15/video
OpenRouter LLM for dream analysis ~$0.01-0.03/request
Google Sheets Dream journal storage Free
How to customize
  • Change LLM: Replace OpenRouter with OpenAI, Anthropic, or other providers
  • Add styles: Edit the STYLES object in "Parse Dream Command" node
  • Modify analysis: Edit system prompt in "AI Dream Analyzer Agent" node
  • Change video model: Replace Veo3 URL with Kling, Luma, or other fal.ai models
  • Skip logging: Remove or disable the Google Sheets node
Commands
Command Description
/dream [text] Generate video in cinematic style
/dream [style] [text] Generate with specific style
/styles Show all available styles
Example
Input: /dream ghibli I was flying over a forest where the trees had glowing leaves
Output: 8-second AI video with magical Ghibli-style visuals, ambient soundtrack, plus psychological analysis of flight symbolism and nature connection themes.
