Track SERP rankings & discover keywords using DataForSEO & Airtable
Last update 24 days ago
Categories
Automated SEO Data Engine using DataForSEO & Airtable
This workflow automatically pulls SERP rankings, competitor keywords, and related keyword ideas from DataForSEO and stores structured results in Airtable — making SEO tracking and keyword research streamlined and automated.
🏗️ What this automation does
Step Component Purpose
1 Trigger (Manual: “Execute workflow”) Starts the workflow on demand — optionally replaceable with a schedule or webhook.
2 Read seed keywords from Airtable (SERP Keywords table) Fetches the list of keywords for which to track SERP.
3 Post SERP task to DataForSEO API Requests Google organic SERP results (depth up to 10) for each keyword.
4 Wait + Poll for results (after ~1 min) Gives DataForSEO time to process, then retrieves the completed task results.
5 Parse & store SERP results into Airtable (SERP rankings table) Records rank, URL, domain, title, description, breadcrumb, etc. for each result.
6 Read competitor list from Airtable (Competitor Research table) Fetches competitors (domains/sites) marked for keyword research.
7 Post competitor-site keywords task to DataForSEO Fetches keywords used by competitor sites.
8 Wait + Poll + Store competitor keywords into Airtable (Competitor Keywords Research) Captures keyword, competition level, search volume, CPC, monthly volume trends.
9 Aggregate seed keywords → request related keywords via DataForSEO Retrieves related / similar keyword ideas for seed list (keyword expansion).
10 Store related keywords into Airtable (Similar Keywords table) Saves keyword data for long-tail / expansion analysis.
📌 Key Integrations & Tools
  • n8n — Workflow automation and orchestration
  • Airtable — Storage for seed keywords, competitor list, and all result tables (SERP Rankings, Competitor Keywords, Similar Keywords)
  • DataForSEO API — For SERP data, competitor-site keywords, and related keyword suggestions
  • Core n8n nodes: Trigger, HTTP Request, Wait, Split Out, Aggregate, Airtable (search & create)
📄 Data Output / Stored Fields
SERP Rankings
  • type, rank_group, rank_absolute, page, domain, title, description, url, breadcrumb
  • Linked to original seed keyword via SERP Keywords reference
Competitor Keywords & Similar Keywords
  • Keyword
  • Competition, Competition_Index
  • Search_Volume, CPC, Low_Top_Of_Page_Bid, High_Top_Of_Page_Bid (if available)
  • Monthly search-volume fields: Jan_2025, Feb_2025, …, Dec_2025 (mapped from API's monthly_searches)
  • For competitor keywords: linked to competitor (company/domain)
  • For similar keywords: linked to seed keyword
🔔 Important Notes
  • Month-volume mapping: Ensure the index mapping from API’s monthly_searches to months is correct — wrong indices will mislabel month data.
  • Fixed wait time: Current 1-minute wait may not always suffice — for large workloads or slow API responses, increase wait or implement polling/backoff logic.
  • No deduplication: Running repeatedly may produce duplicate Airtable records. Consider adding search-or-update logic to avoid duplicates.
  • Rate limits / quotas: Airtable and DataForSEO have limits — batch carefully, throttle requests or add spacing to avoid hitting limits.
  • Credentials security: Store Airtable and DataForSEO API credentials securely in n8n’s credentials manager — avoid embedding tokens directly in workflow JSON.
🚀 Why this Workflow is Useful
  • Fully automates SERP tracking and competitor keyword research — no manual work needed after setup
  • Maintains structured, historical data in Airtable — ideal for tracking rank changes, discovering competitor moves, and keyword expansion over time
  • Great for SEO teams, agencies, content owners, or anyone needing systematic keyword intelligence and monitoring
🌟 Recommended Next Steps
  • Replace manual trigger with a Schedule Trigger (daily/weekly) for automated runs
  • Add deduplication (upsert) logic to prevent duplicate records and keep Airtable clean
  • Improve robustness: add retry logic for API failures, rate-limit handling, and error notifications (Slack / email)
  • Add logging of API response data (task IDs, raw responses) for debugging and audit trails
  • (Optional) Build a reporting dashboard (Airtable Interface / BI tool) to visualise rank trends, keyword growth, and competitor comparisons
📝 Usage / Setup Checklist
  1. Configure Airtable base / tables: SERP Keywords, Competitor Research, SERP rankings, Competitor Keywords Research, Similar Keywords.
  2. Add credentials in n8n: Airtable API token; DataForSEO API credentials (HTTP Basic / Header auth).
  3. Import this workflow JSON into your n8n instance.
  4. Update any base/table/field IDs if different.
  5. (Optional) Replace Manual Trigger with Schedule Trigger, enable workflow.
  6. Run once with a small seed list — verify outputs, schema, and month-volume mapping.
  7. Enable periodic runs and monitor for rate limits or API errors.
