IoT sensor monitoring with GPT-4o anomaly detection, MQTT & multi-channel alerts
Created by: TOMOMITSU ASANO || tomo-0310
TOMOMITSU ASANO
Last update 22 days ago
"name": "IoT Sensor Data Aggregation with AI-Powered Anomaly Detection",
"nodes": [
"parameters": {
"content": "## How it works\nThis workflow monitors IoT sensors in real-time. It ingests data via MQTT or a schedule, normalizes the format, and removes duplicates using data fingerprinting. An AI Agent then analyzes readings against defined thresholds to detect anomalies. Finally, it routes alerts to Slack or Email based on severity and logs everything to Google Sheets.\n\n## Setup steps\n1. Configure the MQTT Trigger with your broker details.\n2. Set your specific limits in the Define Sensor Thresholds node.\n3. Connect your OpenAI credential to the Chat Model node.\n4. Authenticate the Gmail, Slack, and Google Sheets nodes.\n5. Create a Google Sheet with headers: timestamp, sensorId, location, readings, analysis.",
"height": 484,
"width": 360
"id": "298da7ff-0e47-4b6c-85f5-2ce77275cdf3",
"name": "Main Overview",
"type": "n8n-nodes-base.stickyNote",
"typeVersion": 1,
"position": [
-2352,
-480
"parameters": {
"content": "## 1. Data Ingestion\nCaptures sensor data via MQTT for real-time streams or runs on a schedule for batch processing. Both streams are merged for unified handling.",
"height": 488,
"width": 412,
"color": 7
"id": "4794b396-cd71-429c-bcef-61780a55d707",
"name": "Section: Ingestion",
"typeVersion": 1,
"position": [
-1822,
-48
"parameters": {
"content": "## 2. Normalization & Deduplication\nSets monitoring thresholds, standardizes the JSON structure, creates a content hash, and filters out duplicate readings to prevent redundant API calls.",
"height": 316,
"width": 884,
"color": 7
"id": "339e7cb7-491e-44c9-b561-983e147237d8",
"name": "Section: Processing",
"typeVersion": 1,
"position": [
-1376,
32
"parameters": {
"content": "## 3. AI Anomaly Detection\nAn AI Agent evaluates sensor data against thresholds to identify anomalies, assigning severity levels and providing actionable recommendations.",
"height": 528,
"width": 460,
"color": 7
"id": "ebcb7ca3-f70c-4a90-8a2a-f489e7be4c73",
"name": "Section: AI Analysis",
"typeVersion": 1,
"position": [
-422,
24
"parameters": {
"content": "## 4. Routing & Archiving\nRoutes alerts based on severity (Critical = Email+Slack, Warning = Slack) and archives all data points to Google Sheets for historical analysis.",
"height": 756,
"width": 900,
"color": 7
"id": "7f2b32a5-d3b2-4fea-844f-4b39b8e8a239",
"name": "Section: Alerting",
"typeVersion": 1,
"position": [
94,
-196
"parameters": {
"topics": "sensors/+/data",
"options": {}
"id": "bc86720b-9de9-4693-b090-343d3ebad3a3",
"name": "MQTT Sensor Trigger",
"type": "n8n-nodes-base.mqttTrigger",
"typeVersion": 1,
"position": [
-1760,
88
"parameters": {
"rule": {
"interval": [
"field": "minutes",
"minutesInterval": 15
"id": "1c38f2d0-aa00-447e-bdae-bffd08c38461",
"name": "Batch Process Schedule",
"type": "n8n-nodes-base.scheduleTrigger",
"typeVersion": 1.2,
"position": [
-1760,
280
"parameters": {
"mode": "chooseBranch"
"id": "f9b41822-ee61-448b-b324-38483036e0e1",
"name": "Merge Triggers",
"type": "n8n-nodes-base.merge",
"typeVersion": 3,
"position": [
-1536,
184
"parameters": {
"mode": "raw",
"jsonOutput": "{\n "thresholds": {\n "temperature": {"min": -10, "max": 50, "unit": "C"},\n "humidity": {"min": 20, "max": 90, "unit": "%"},\n "pressure": {"min": 950, "max": 1050, "unit": "hPa"},\n "co2": {"min": 400, "max": 2000, "unit": "ppm"}\n },\n "alertConfig": {\n "criticalChannel": "#iot-critical",\n "warningChannel": "#iot-alerts",\n "emailRecipients": "[email protected]"\n }\n}",
"options": {}
"id": "308705a8-edc7-4435-9250-487aa528e033",
"name": "Define Sensor Thresholds",
"type": "n8n-nodes-base.set",
"typeVersion": 3.4,
"position": [
-1312,
184
"parameters": {
"jsCode": "const items = $input.all();\nconst thresholds = $('Define Sensor Thresholds').first().json.thresholds;\nconst results = [];\n\nfor (const item of items) {\n let sensorData;\n try {\n sensorData = typeof item.json.message === 'string' \n ? JSON.parse(item.json.message) \n : item.json;\n } catch (e) {\n sensorData = item.json;\n }\n \n const now = new Date();\n const reading = {\n sensorId: sensorData.sensorId || sensorData.topic?.split('/')[1] || 'unknown',\n location: sensorData.location || 'Main Facility',\n timestamp: now.toISOString(),\n readings: {\n temperature: sensorData.temperature ?? null,\n humidity: sensorData.humidity ?? null,\n pressure: sensorData.pressure ?? null,\n co2: sensorData.co2 ?? null\n },\n metadata: {\n receivedAt: now.toISOString(),\n source: item.json.topic || 'batch',\n thresholds: thresholds\n }\n };\n \n results.push({ json: reading });\n}\n\nreturn results;"
"id": "a2008189-5ace-418b-b0db-d51d63dcf2d8",
"name": "Parse Sensor Payload",
"type": "n8n-nodes-base.code",
"typeVersion": 2,
"position": [
-1088,
184
"parameters": {
"type": "SHA256",
"value": "={{ $json.sensorId + '-' + $json.timestamp + '-' + JSON.stringify($json.readings) }}",
"dataPropertyName": "dataHash"
"id": "bf8db555-a10e-4468-a44a-cdc4c97e5b80",
"name": "Generate Data Fingerprint",
"type": "n8n-nodes-base.crypto",
"typeVersion": 1,
"position": [
-864,
184
"parameters": {
"compare": "selectedFields",
"fieldsToCompare": "dataHash",
"options": {}
"id": "a45405e2-d211-449d-84d7-4538eaf56fcd",
"name": "Remove Duplicate Readings",
"type": "n8n-nodes-base.removeDuplicates",
"typeVersion": 1,
"position": [
-640,
184
"parameters": {
"text": "=Analyze this IoT sensor reading and determine if there are any anomalies:\n\nSensor ID: {{ $json.sensorId }}\nLocation: {{ $json.location }}\nTimestamp: {{ $json.timestamp }}\n\nReadings:\n- Temperature: {{ $json.readings.temperature }}°C (Normal: {{ $json.metadata.thresholds.temperature.min }} to {{ $json.metadata.thresholds.temperature.max }})\n- Humidity: {{ $json.readings.humidity }}% (Normal: {{ $json.metadata.thresholds.humidity.min }} to {{ $json.metadata.thresholds.humidity.max }})\n- CO2: {{ $json.readings.co2 }} ppm (Normal: {{ $json.metadata.thresholds.co2.min }} to {{ $json.metadata.thresholds.co2.max }})\n\nProvide your analysis in this exact JSON format:\n{\n "hasAnomaly": true/false,\n "severity": "critical"/"warning"/"normal",\n "anomalies": ["list of detected issues"],\n "reasoning": "explanation of your analysis",\n "recommendation": "suggested action"\n}",
"options": {
"systemMessage": "You are an IoT monitoring expert. Analyze sensor data and detect anomalies based on the provided thresholds. Be precise and provide actionable recommendations. Always respond in valid JSON format."
"id": "b60194ba-7b99-44e0-b0d7-9f1632dce4d4",
"name": "AI Anomaly Detector",
"type": "@n8n/n8n-nodes-langchain.agent",
"typeVersion": 1.7,
"position": [
-416,
184
"parameters": {
"jsCode": "const item = $input.first();\nconst originalData = $('Remove Duplicate Readings').first().json;\n\nlet aiAnalysis;\ntry {\n const responseText = item.json.output || item.json.text || '';\n const jsonMatch = responseText.match(/\{[\s\S]\}/);\n aiAnalysis = jsonMatch ? JSON.parse(jsonMatch[0]) : {\n hasAnomaly: false,\n severity: 'normal',\n anomalies: [],\n reasoning: 'Unable to parse AI response',\n recommendation: 'Manual review required'\n };\n} catch (e) {\n aiAnalysis = {\n hasAnomaly: false,\n severity: 'normal',\n anomalies: [],\n reasoning: 'Parse error: ' + e.message,\n recommendation: 'Manual review required'\n };\n}\n\nreturn [{\n json: {\n ...originalData,\n analysis: aiAnalysis,\n alertLevel: aiAnalysis.severity,\n requiresAlert: aiAnalysis.hasAnomaly && aiAnalysis.severity !== 'normal'\n }\n}];"
"id": "a145a8c7-538c-411a-95c6-9485acdcb969",
"name": "Parse AI Analysis",
"typeVersion": 2,
"position": [
-64,
184
"parameters": {
"rules": {
"values": [
"conditions": {
"options": {
"caseSensitive": true,
"typeValidation": "strict"
"combinator": "and",
"conditions": [
"id": "critical",
"operator": {
"type": "string",
"operation": "equals"
"leftValue": "={{ $json.alertLevel }}",
"rightValue": "critical"
"renameOutput": true,
"outputKey": "Critical"
"conditions": {
"options": {
"conditions": [
"id": "warning",
"operator": {
"type": "string",
"rightValue": "warning"
"outputKey": "Warning"
"options": {
"fallbackOutput": "extra"
"id": "1ab9785d-9f7f-4840-b1e9-0afc62b00b12",
"name": "Route by Severity",
"type": "n8n-nodes-base.switch",
"typeVersion": 3.2,
"position": [
160,
168
"parameters": {
"sendTo": "={{ $('Define Sensor Thresholds').first().json.alertConfig.emailRecipients }}",
"subject": "=CRITICAL IoT Alert: {{ $json.sensorId }} - {{ $json.analysis.anomalies[0] || 'Anomaly Detected' }}",
"message": "=CRITICAL IoT SENSOR ALERT\n\nSensor: {{ $json.sensorId }}\nLocation: {{ $json.location }}\nTime: {{ $json.timestamp }}\n\nReadings:\n- Temperature: {{ $json.readings.temperature }}°C\n- Humidity: {{ $json.readings.humidity }}%\n- CO2: {{ $json.readings.co2 }} ppm\n\nAI Analysis:\n{{ $json.analysis.reasoning }}\n\nDetected Issues:\n{{ $json.analysis.anomalies.join('\n- ') }}\n\nRecommendation:\n{{ $json.analysis.recommendation }}",
"options": {}
"id": "28201a6c-10b5-4387-be89-10a57c634622",
"name": "Send Critical Email",
"type": "n8n-nodes-base.gmail",
"typeVersion": 2.1,
"position": [
384,
-80
"webhookId": "35b9f8fa-4a50-456e-b552-9fd20a25ccc5"
"parameters": {
"select": "channel",
"channelId": {
"__rl": true,
"mode": "name",
"value": "#iot-critical"
"text": "=🚨 CRITICAL IoT ALERT\n\n
Sensor:* {{ $json.sensorId }}\nLocation: {{ $json.location }}\n\nReadings:\n• Temperature: {{ $json.readings.temperature }}°C\n• Humidity: {{ $json.readings.humidity }}%\n• CO2: {{ $json.readings.co2 }} ppm\n\nAI Analysis: {{ $json.analysis.reasoning }}\nRecommendation: {{ $json.analysis.recommendation }}",
"otherOptions": {}
"id": "c5a297be-ccef-40ba-9178-65805262efba",
"name": "Slack Critical Alert",
"type": "n8n-nodes-base.slack",
"typeVersion": 2.2,
"position": [
384,
112
"webhookId": "19113595-0208-4b37-b68c-c9788c19f618"
"parameters": {
"channelId": {
"__rl": true,
"mode": "name",
"value": "#iot-alerts"
"text": "=⚠️ IoT Warning\n\nSensor: {{ $json.sensorId }} | Location: {{ $json.location }}\nIssue: {{ $json.analysis.anomalies[0] || 'Threshold approaching' }}\nRecommendation: {{ $json.analysis.recommendation }}",
"otherOptions": {}
"id": "5c3d7acf-0211-44dd-9f4b-a43d3796abb1",
"name": "Slack Warning Alert",
"typeVersion": 2.2,
"position": [
384,
400
"webhookId": "37abfb19-f82f-4449-bd69-a65635b99606"
"parameters": {},
"id": "6bcbb42f-ec14-4f00-a091-babcc2d2d5c4",
"name": "Merge Alert Outputs",
"typeVersion": 3,
"position": [
608,
184
"parameters": {
"operation": "append",
"documentId": {
"__rl": true,
"mode": "list",
"value": ""
"sheetName": {
"__rl": true,
"mode": "list",
"value": ""
"id": "6243aa23-408d-4928-a512-811eeb3b5f9e",
"name": "Archive to Google Sheets",
"type": "n8n-nodes-base.googleSheets",
"typeVersion": 4.5,
"position": [
832,
184
"parameters": {
"model": "gpt-4o-mini",
"options": {
"temperature": 0.3
"id": "61081e8a-ebc9-465f-8beb-88af225e59f2",
"name": "OpenAI Chat Model",
"type": "@n8n/n8n-nodes-langchain.lmChatOpenAi",
"typeVersion": 1.2,
"position": [
-344,
408
"pinData": {},
"connections": {
"MQTT Sensor Trigger": {
"main": [
"node": "Merge Triggers",
"type": "main",
"index": 0
"Batch Process Schedule": {
"main": [
"type": "main",
"index": 1
"Merge Triggers": {
"main": [
"node": "Define Sensor Thresholds",
"type": "main",
"index": 0
"Define Sensor Thresholds": {
"main": [
"node": "Parse Sensor Payload",
"type": "main",
"index": 0
"Parse Sensor Payload": {
"main": [
"node": "Generate Data Fingerprint",
"type": "main",
"index": 0
"Generate Data Fingerprint": {
"main": [
"node": "Remove Duplicate Readings",
"type": "main",
"index": 0
"Remove Duplicate Readings": {
"main": [
"node": "AI Anomaly Detector",
"type": "main",
"index": 0
"AI Anomaly Detector": {
"main": [
"node": "Parse AI Analysis",
"type": "main",
"index": 0
"Parse AI Analysis": {
"main": [
"node": "Route by Severity",
"type": "main",
"index": 0
"Route by Severity": {
"main": [
"node": "Send Critical Email",
"type": "main",
"index": 0
"node": "Slack Critical Alert",
"type": "main",
"index": 0
"node": "Slack Warning Alert",
"type": "main",
"index": 0
"node": "Merge Alert Outputs",
"type": "main",
"index": 0
"Send Critical Email": {
"main": [
"type": "main",
"index": 0
"Slack Critical Alert": {
"main": [
"type": "main",
"index": 0
"Slack Warning Alert": {
"main": [
"type": "main",
"index": 0
"Merge Alert Outputs": {
"main": [
"node": "Archive to Google Sheets",
"type": "main",
"index": 0
"OpenAI Chat Model": {
"ai_languageModel": [
"type": "ai_languageModel",
"index": 0
"active": false,
"settings": {
"executionOrder": "v1"
"versionId": "",
"meta": {
"instanceId": "15d6057a37b8367f33882dd60593ee5f6cc0c59310ff1dc66b626d726083b48d"
"tags": []
