Monitor and alert stalled deals in Zoho CRM with Gemini AI and Gmail
Created by: WeblineIndia || weblineindia
WeblineIndia
Last update 22 days ago
Zoho CRM – Deal Health Predictor with AI Scoring
This n8n automation monitors open Zoho CRM Deals every week, identifies stalled opportunities, scores their health using Google Gemini AI and triggers sales intervention by emailing the deal owner and creating a high-priority task in Zoho CRM — before the deal goes cold.
Quick Start — Implementation in 6 Steps
  1. Import workflow into your n8n instance.
  2. Connect Zoho OAuth2 credential in all Zoho nodes.
  3. Connect Gmail OAuth2 account for outbound alerts.
  4. Confirm stage names & inactivity thresholds match your CRM.
  5. Test with sample deals before scheduling.
  6. Activate the workflow once validated by your sales team.
What It Does
This workflow dynamically analyzes every open sales deal retrieved from Zoho CRM. It calculates key metrics per deal such as inactivity duration, stage aging and deal age to understand whether the opportunity has stalled. Only deals with significant inactivity move forward to AI scoring.
Using Google Gemini, each deal receives a Health Score (0–100), along with a risk level, reasons and recommended next actions. If a deal is considered “At-Risk,” the system automatically:
  • Sends an alert email to the assigned sales rep
  • Creates a high-priority Task in Zoho CRM linked to that deal
It ensures timely sales intervention without needing manual checks.
Who’s It For
  • Sales teams using Zoho CRM
  • RevOps & Sales Managers monitoring deal movement
  • Teams wanting data-backed alerts for slow-moving deals
  • Businesses wanting proactive pipeline management with AI
Requirements
Requirement Why
n8n instance (Self-hosted or Cloud) Runs the workflow
Zoho CRM OAuth2 Credentials Fetch deals + Create tasks
Gmail (or SMTP) credentials Send alert emails
Google Gemini API access AI scoring on deals
Deals must have Stage + Owner + Activity history Ensures accurate scoring
How It Works — Setup & Configuration Steps
Step-by-Step Setup
  1. Import workflow into n8n
  2. Enable Zoho CRM OAuth2 credentials in:
    • Fetch Open Deals
    • Create At-Risk Task
  3. Enable Gmail OAuth2 on the email alert node
  4. Validate fields from Zoho API:
    • Last_Activity_Time
    • Stage
    • Owner.email
  5. Update the deal stage list in the Fetch URL if needed:
    • Example: Qualification, Negotiation, Proposal, etc.
  6. Confirm scanning frequency in the Weekly Trigger
  7. Run the workflow manually once → check logs + emails + tasks
  8. Turn workflow Active
How To Customize Nodes
Node What You Can Customize Example
Weekly Trigger Change execution frequency Daily scan
Fetch Deals Include additional deal stages Add “Value Proposition”
Filter Stalled Deals Adjust inactivity threshold > 15 days instead of 30
AI Prompt Add more data points Probability to close
Email Alert Modify message template Localization
Task creation Add reminder / follow-up info Due date +1 day
Add-Ons (Optional Enhancements)
You can easily extend this workflow by adding:
  • Stage Change Webhook Trigger → near real-time monitoring
  • Google Sheets or Database Logging for reporting
  • Duplicate task checker so the same deal isn’t flagged repeatedly
  • Slack / Microsoft Teams alerts
  • SLA-based scoring (pipeline aging logic)
  • Manager escalation if no response in X days
Practical Use Cases
This workflow is ideal for:
  1. Sales manager auto-alert system for aging deals
  2. Leaderboard tracking for untouched deals
  3. Weekly CRM hygiene and rep performance tracking
  4. Early detection of churn risk in B2B sales cycles
  5. AI-assisted deal coaching and next-step suggestions
Many more scenarios are possible based on deal movement automation.
Troubleshooting Guide
Issue Possible Cause Fix / Solution
No deals processed Stage filters too narrow Update fetch URL stage list
Emails not sent Gmail credentials missing or expired Reconnect Gmail OAuth2
Tasks not created Zoho API permissions missing Enable write permissions
Owner email missing CRM field not mapped correctly Update sendTo expression
Health score always null Output parser mismatch Check prompt & parser config
Workflow runs but no alerts sent No stalled deals or score >= threshold Temporarily lower threshold for testing
Need Help?
If you would like expert help customizing this workflow or implementing additional automation like stage-based triggers, dashboards or integration with Slack/Teams, our n8n automation team at WeblineIndia can assist you.
