Monitor Cloudflare incidents and alert via Slack, Telegram, and Jira
Created by: Trung Tran || trungtran
Trung Tran
Last update 2 months ago
Cloudflare Incident Monitoring & Escalation Workflow
🚀 Try Decodo — Web Scraping & Data API (Coupon: TRUNG)
Decodo Logo
Decodo is a powerful public data access platform offering managed web scraping APIs and proxy infrastructure to collect structured web data at scale. It handles proxies, anti-bot protection, JavaScript rendering, retries, and global IP rotation—so you can focus on data, not scraping complexity.
Why Decodo
  • Managed Web Scraping API with anti-bot bypass & high success rates
  • Works with JS-heavy sites; outputs JSON/HTML/CSV
  • Easy integration (Python, Node.js, cURL) for eCommerce, SERP, social & general web data
    🎟️ Special Discount
    Use coupon TRUNG to get the Advanced Scraping API plan — ~23,000 requests for ~$5.
Who this workflow is for
For DevOps, SRE, IT Ops, and Platform teams running production traffic behind Cloudflare who need reliable incident awareness without alert fatigue.
Use it if you want:
  • Continuous Cloudflare incident monitoring
  • Clear severity-based routing
  • Automatic escalation into JIRA
  • Clean Slack & Telegram notifications
  • Deduplicated, noise-controlled alerts
What this workflow does
This workflow polls the Cloudflare Status API, detects unresolved incidents, scores their impact, and routes them to the right channels.
High-impact incidents are escalated to JIRA.
Lower-impact updates are notified (or skipped) to reduce noise.
How it works (high level)
  1. Runs on a fixed schedule (e.g. every 5 minutes)
  2. Fetches current Cloudflare incidents
  3. Stops early if no active issues exist
  4. Normalizes and scores incidents (severity, impact, affected service)
  5. Deduplicates previously-alerted incidents
  6. Builds human-readable notification payloads
  7. Routes by impact:
    • High → create JIRA incident + notify
    • Low → notify or suppress
  8. Sends alerts to Slack and Telegram
Requirements
  • Decoco Scrapper API credential
  • n8n (self-hosted or Cloud)
  • Cloudflare Status API (public)
  • Slack bot (chat:write)
  • Telegram bot + chat ID
  • JIRA project with issue-create permission
  • Optional LLM credentials (summarization/classification)
Notes
  • All secrets are stored in n8n Credentials
  • Workflow is idempotent and safe to rerun
  • No assumptions about root cause or remediation
    Built for production-grade incident visibility with n8n.
