Schedule BlueSky posts and threads using Google Sheets as content calendar
Created by: Soumya Sahu || sahu
Soumya Sahu
Last update 23 days ago
This workflow turns a Google Sheet into a fully automated content calendar for BlueSky. It handles single posts, multi-post threads, and image attachments, allowing you to manage your entire social presence from a simple spreadsheet.
Who is this for
Ideal for social media managers, content creators, and growth marketers who want to schedule content in bulk without using expensive third-party tools.
What it does
It runs on a schedule to check your Google Sheet for posts marked "Ready." It automatically handles:
  • Threading: Links posts together if they share a Thread ID and Sequence.
  • Images: Downloads image URLs and uploads them as blobs to BlueSky.
  • Status Updates: Marks rows as "Posted" and saves the live URL back to your sheet.
How to set up
  1. Google Sheet: Create a sheet with these columns: Content, Thread ID, Sequence (use '1' for single posts), Image URL, Scheduled Time, Status, Post Link.
    • Important: Even if it is a single post (not a thread), you must add a unique Thread ID.
    • Note: Image URL is optional.
    • Format: Set the "Scheduled Time" column type to Plain Text to prevent date errors.
    • (A sample Google Sheet link is provided inside the workflow notes).
  2. Credentials: Enter your BlueSky Handle and App Password in the "Configuration" node.
  3. Select Sheet: In both the "Get row(s)" and "Update row" nodes, select your specific Google Sheet.
🚀 The BlueSky Growth Suite
This workflow is part of a 3-part automation suite designed to help you grow on BlueSky:
  • Part 1: Post Scheduler (This template)
  • Part 2: Analytics Tracker (Track likes/reposts back to Sheets)
  • Part 3: Lead Magnet Bot (Auto-DM users who reply to your posts)
