Estimate construction costs from text, photos and PDFs with Telegram, GPT‑4/Gemini and DDC CWICR
Created by: Artem Boiko || datadrivenconstruction
Artem Boiko
Last update a month ago
A full-featured Telegram bot that accepts text descriptions, photos, or PDF floor plans and returns detailed cost estimates with work breakdown. Powered by GPT-4 Vision / Gemini 2.0, vector search, and the open-source DDC CWICR database (55,000+ construction rates).
Who's it for
  • Contractors & Estimators who need estimates from any input format
  • Construction managers evaluating scope from site photos or drawings
  • Architects getting quick cost feedback on floor plans
  • Real estate professionals assessing renovation costs
  • Project managers doing rapid feasibility checks via mobile
What it does
  1. Receives text / photo / PDF via Telegram
  2. Analyzes input with AI (Gemini 2.0 Flash or GPT-4 Vision)
  3. Extracts work items with quantities and units
  4. Searches DDC CWICR vector database for matching rates
  5. Generates professional HTML report with full cost breakdown
  6. Exports results as Excel or PDF
Supports 9 languages: 🇩🇪 DE · 🇬🇧 EN · 🇷🇺 RU · 🇪🇸 ES · 🇫🇷 FR · 🇮🇹 IT · 🇵🇱 PL · 🇧🇷 PT · 🇺🇦 UK
│                        TELEGRAM INPUT                                │
│  📝 Text Description  │  📷 Construction Photo  │  📄 PDF Floor Plan │
│                         MAIN ROUTER                                  │
│  Parse message → Detect content type → Route to handler (17 actions) │
│  Text LLM       │     │  Vision API     │     │  Vision PDF     │
│  Parse works    │     │  Analyze photo  │     │  Read floor plan│
│  from text      │     │  GPT-4/Gemini   │     │  Gemini 2.0     │
│                    CALCULATION LOOP                                  │
│  For each work item:                                                 │
│  1️⃣ Transform query → 2️⃣ Optimize search → 3️⃣ Get embedding         │
│  4️⃣ Qdrant search → 5️⃣ Score results → 6️⃣ AI rerank → 7️⃣ Calculate  │
│                      OUTPUT                                          │
│  📊 Telegram message  │  🌐 HTML Report  │  📑 Excel  │  📄 PDF      │
Input Types
Type Description AI Used
📝 Text Work lists, specifications, notes OpenAI GPT-4
📷 Photo Construction site photos (up to 4) GPT-4 Vision / Gemini
📄 PDF Floor plans, architectural drawings Gemini 2.0 Flash
Route Actions (17 total)
# Action Description
0 show_lang Language selection menu
1 ask_photo Request photo upload
2 lang_selected Save language preference
3 show_analyze Photo analysis options
4 analyze Run AI vision analysis
5 show_edit_menu Edit work quantities
6 works_updated After quantity change
7 ask_new_work Add manual work item
8 start_calc Start cost calculation
9 show_help Display help message
10 view_details Show resource details
11 export_excel Generate CSV export
12 export_pdf Generate PDF export
13 process_pdf Analyze PDF floor plan
14 analyze_text Parse text description
15 refine Re-analyze with context
16 fallback Handle unknown input
Prerequisites
Component Requirement
n8n v1.30+ with Telegram Trigger
Telegram Bot Token from @BotFather
OpenAI API For embeddings + text parsing
Gemini API For Vision (photos/PDF) — or use GPT-4 Vision
Qdrant Vector DB with DDC CWICR collections
DDC CWICR Data github.com/datadrivenconstruction/DDC-CWICR
1. Configure 🔑 TOKEN Node
  "bot_token": "YOUR_TELEGRAM_BOT_TOKEN",
  "AI_PROVIDER": "gemini",
  "GEMINI_API_KEY": "YOUR_GEMINI_KEY",
  "OPENAI_API_KEY": "YOUR_OPENAI_KEY",
  "QDRANT_URL": "http://localhost:6333",
  "QDRANT_API_KEY": "YOUR_QDRANT_KEY"
2. Vision Provider Selection
  • AI_PROVIDER: "gemini" → Gemini 2.0 Flash (recommended for photos + PDF)
  • AI_PROVIDER: "openai" → GPT-4 Vision (photos only)
3. n8n Credentials
  1. SettingsCredentialsAddTelegram API
  2. Enter bot token, save
  3. Select credential in Telegram Trigger node
4. Qdrant Collections
Load DDC CWICR embeddings for target languages (example for Russian):
RU_STPETERSBURG_workitems_costs_resources_EMBEDDINGS_3072_DDC_CWICR
5. Activate & Test
  1. Activate workflow
  2. Send /start to your bot
  3. Select language → send photo/text/PDF
Features
Feature Description
📷 Photo Analysis GPT-4 Vision or Gemini 2.0 for site photos
📄 PDF Processing Floor plan analysis with room extraction
📝 Text Parsing Natural language work lists
🔍 Vector Search Semantic matching via Qdrant + OpenAI embeddings
🤖 AI Reranking LLM-based result scoring for accuracy
✏️ Inline Editing Modify quantities via Telegram buttons
📊 HTML Report Professional expandable report with KPIs
📑 Excel Export CSV with full work breakdown
📄 PDF Export HTML-based PDF document
🌍 9 Languages Full UI + database localization
💾 Session State Multi-turn conversation support
🔧 Refine Mode Re-analyze with additional context
Example Workflow
User: /start
Bot: Language selection menu (9 options)
User: Selects 🇷🇺 Russian
Bot: "Отправьте фото, PDF или текстовое описание работ"
User: Sends bathroom photo
Bot: "📷 Анализ фото... ⏳"
Bot: Shows detected works:
🏠 Ванная комната — 4.5 m²
Найдено 12 работ:
1. Демонтаж плитки стен — 18 m²
2. Демонтаж плитки пола — 4.5 m²
3. Гидроизоляция пола — 4.5 m²
4. Гидроизоляция стен — 8 m²
5. Стяжка пола — 4.5 m²
6. Укладка плитки стены — 18 m²
7. Укладка плитки пол — 4.5 m²
8. Установка унитаза — 1 шт
9. Установка раковины — 1 шт
10. Установка смесителя — 2 шт
[✏️ Редактировать] [📊 Рассчитать]
User: Taps 📊 Calculate
Bot: Shows progress per item, then final result:
✅ Смета готова — 12 позиций
💰 Итого: ₽ 89,450
Работа: ₽ 35,200 (39%)
Материалы: ₽ 48,750 (55%)
Механизмы: ₽ 5,500 (6%)
[📋 Детали] [↓ Excel] [↓ PDF] [↻ Заново]
HTML Report Features
  • KPI Cards: Total cost, item count, labor days, cost breakdown %
  • Expandable rows: Click work item to show resources
  • Resource tags: Color-coded (Labor/Material/Machine)
  • Scope of work: Expandable detailed descriptions
  • Quality indicators: Match quality dots (high/medium/low)
  • Responsive design: Works on mobile and desktop
  • Export buttons: Expand/Collapse all
Notes & Tips
  • Photo tips: Capture full room, include reference objects (doors, tiles)
  • PDF support: Works best with clear floor plans and room schedules
  • Text input: Supports lists, tables, free-form descriptions
  • Rate accuracy: Depends on DDC CWICR coverage for your region
  • Session timeout: User sessions persist across messages
  • Extend: Chain with CRM, project management, or notification tools
Categories
AI · Communication · Data Extraction · Document Ops
Tags
telegram-bot, construction, cost-estimation, gpt-4-vision, gemini, pdf-analysis, qdrant, vector-search, multilingual, html-report
Author
DataDrivenConstruction.io
https://DataDrivenConstruction.io
[email protected]
Consulting & Training
We help construction, engineering, and technology firms implement:
  • AI-powered estimation systems (text, photo, PDF)
  • Multi-channel bot integrations (Telegram, WhatsApp, Web)
  • Vector database solutions for construction data
  • Multilingual cost database deployment
Contact us to test with your data or adapt to your project requirements.
Resources
Star us on GitHub! github.com/datadrivenconstruction/DDC-CWICR
