E-commerce product mockups from images with OpenAI DALL-E, remove.bg and G-Drive
Last update 11 days ago
Who it's for
This n8n workflow automatically generates professional e-commerce product mockups from product images. The workflow is perfect for e-commerce store owners, product marketers, and content creators who need to create consistent, high-quality product visuals for their online stores, social media, and marketing materials.
Features
  • Dual Input Methods: Accepts product images via file upload or URL
  • Background Removal: Automatically removes backgrounds from product images using remove.bg API
  • AI-Powered Mockups: Generates premium e-commerce mockups using OpenAI's DALL-E
  • Professional Prompts: Uses detailed design prompts for luxury e-commerce aesthetics
  • Google Drive Integration: Automatically saves both PNG files and final mockups to Google Drive
How It Works
  1. The workflow starts with a form submission where users provide:
    • Product image (file upload or URL)
    • Product name/title
  2. System detects whether the image is a file or a URL.
  3. For uploaded files:
    • Processed through remove.bg to remove the background
    • Transparent PNG is uploaded to Google Drive
    • OpenAI generates a professional mockup based on product image
    • Final mockup uploaded on Drive & notify user
  4. For URL inputs:
    • Image downloaded from the URL
    • Background removal and mockup generation process is applied
    • Results are delivered back to the user
Requirements
  • remove.bg API credentials for background removal
  • OpenAI API credentials for DALL-E image generation
  • Google Drive OAuth2 credentials for file storage
Important Notes
  • Image Processing: All images are processed with professional-grade background removal
  • AI Prompting: The workflow uses detailed prompts designed for luxury e-commerce aesthetics
  • File Storage: Both PNG files and final mockups are stored in a designated Google Drive folder
  • Conditional Logic: The workflow intelligently routes based on input type (file vs. URL)
  • Error Handling: Includes retry logic for AI image generation
Support & Help
