Generate audio documentaries from web articles with ElevenLabs and BrowserAct
Last update 17 days ago
Generate audio documentaries from web articles to Telegram with ElevenLabs & BrowserAct
This workflow transforms any web article or blog post into a high-production-value audio documentary. It automates the entire production chain—from scraping content and writing an engaging narrative script to generating realistic voiceovers—delivering a listenable MP3 file directly to your Telegram chat.
Target Audience
Commuters, podcast enthusiasts, content creators, and researchers who prefer listening to content over reading.
  1. Analyze Intent: The workflow receives a message via Telegram. An AI Agent (using Google Gemini) classifies the input to determine if it is a casual chat or a request to process a URL.
  2. Scrape Content: If a valid link is detected, BrowserAct executes a background task to visit the webpage and extract the raw text.
  3. Write Script: A Scriptwriter Agent (using Claude via OpenRouter) converts the dry article text into a dramatic, narrative-driven script optimized for audio, including cues for pacing and tone.
  4. Generate Audio: ElevenLabs synthesizes the script into high-fidelity speech using a specific voice model (e.g., "Liam").
  5. Deliver Output: The workflow sends the generated MP3 file and a formatted HTML summary caption back to the user on Telegram.
How to set up
  1. Configure Credentials: Connect your Telegram, ElevenLabs, OpenRouter, Google Gemini, and BrowserAct accounts in n8n.
  2. Prepare BrowserAct: Ensure the AI Summarization & Eleven Labs Podcast Generation template is saved in your BrowserAct account.
  3. Select Voice: Open the Convert text to speech node and select your preferred ElevenLabs voice model.
  4. Configure Model: Open the OpenRouter node to confirm the model selection (e.g., Claude Haiku) or switch to a different LLM for scriptwriting.
  5. Activate: Turn on the workflow and send a link to your Telegram bot to test it.
Requirements
  • BrowserAct account with the AI Summarization & Eleven Labs Podcast Generation template.
  • ElevenLabs account.
  • OpenRouter account (or access to an LLM like Claude).
  • Google Gemini account.
  • Telegram account (Bot Token).
How to customize the workflow
  1. Change the Persona: Modify the system prompt in the Scriptwriter node to change the narrative style (e.g., from "Documentary Host" to "Comedian" or "News Anchor").
  2. Switch Output Channel: Replace the Telegram output node with a Google Drive or Dropbox node to archive the generated audio files for a podcast feed.
  3. Multi-Voice Support: Add logic to split the script into multiple parts and use different ElevenLabs voices to simulate a conversation between two hosts.
Need Help?
Workflow Guidance and Showcase Video
