Auto-post curated remote jobs to Telegram with BrowserAct and Gemini
Last update a month ago
Auto-post curated remote jobs to Telegram with BrowserAct & Gemini
This workflow acts as an intelligent job board curator for your Telegram community. It scrapes multiple sources (Remotive, SimplyHired), uses AI to filter out spam and low-quality listings, formats the best jobs into professional posts, and publishes them automatically on a schedule.
Target Audience
Community managers running job boards, recruiters, and developers building niche job aggregators.
  1. Scheduled Fetch: Every 12 hours, the workflow triggers BrowserAct to scrape the latest job listings from Remotive and SimplyHired in parallel.
  2. Merge & Aggregate: The raw job data from both sources is combined into a single list.
  3. AI Curation: An AI Agent (using Google Gemini) reviews each job. It removes duplicates, filters out gigs paying less than $20/hr, and discards low-quality descriptions.
  4. Format Content: The AI rewrites the remaining jobs into clean, engaging HTML summaries suitable for Telegram.
  5. Publish: The workflow loops through the curated list and sends each job to your Telegram channel, pausing between messages to avoid rate limits.
How to set up
  1. Configure Credentials: Connect your Telegram, BrowserAct, and Google Gemini accounts in n8n.
  2. Prepare BrowserAct: Ensure you have the Automated Remote Job Fetching & Filtering for Telegram Feed templates (for Remotive and SimplyHired) saved in your BrowserAct account.
  3. Configure Telegram: Ensure your bot is an admin in the target channel and add the Chat ID to the Send a text message node.
  4. Activate: Turn on the workflow.
Requirements
  • BrowserAct account with the Automated Remote Job Fetching & Filtering for Telegram Feed templates.
  • Telegram account (Bot Token).
  • Google Gemini account.
How to customize the workflow
  1. Add More Sources: Duplicate the BrowserAct nodes to scrape additional sites like We Work Remotely or LinkedIn.
  2. Refine Filters: Update the system prompt in the AI Agent node to filter by specific keywords (e.g., "Python", "Senior") or locations.
  3. Change Frequency: Adjust the Schedule Trigger to run more or less frequently depending on your needs.
Need Help?
Workflow Guidance and Showcase Video
