Adjust morning alarms based on weather and train delays using Google Gemini
Created by: NODA shuichi || shuichi
NODA shuichi
Last update 21 days ago
Description: An intelligent alarm system that wakes you up early only when necessary. 🛡️🤖
This workflow monitors your local weather and train status every morning at 5:00 AM. It uses Google Gemini to analyze the situation. If there is heavy rain or a train delay, it sends an emergency alert immediately (and can trigger smart home devices). If everything is normal, it waits until your usual wake-up time to send a calm briefing.
Key Features:
AI Context Awareness: Uses Gemini to intelligently judge "Emergency" situations based on weather descriptions and news headlines.
Dynamic Notification:
Emergency Mode: Immediate Email alert + Optional SwitchBot trigger (e.g., turn on lights).
Normal Mode: Delays notification until your scheduled wake-up time (90 mins later).
Targeted Monitoring: Searches specific train lines via Google News RSS.
How it works:
Trigger: Runs daily at 5:00 AM.
Fetch: Gets weather from OpenWeatherMap and train news from Google News RSS.
Judge: Gemini analyzes the data.
Action: Routes the notification based on the status (Emergency/Normal).
Setup Requirements:
Credentials: OpenWeatherMap API, Google Gemini API, Gmail.
Config: Open the "1. Configuration" node to set your Location, Train Line, and Email.
