Monitor multi-city weather with OpenWeatherMap, GPT-4o-mini, and Discord
Created by: 荒城直也 || naoya-495
荒城直也
Last update 20 days ago
Weather Monitoring Across Multiple Cities with OpenWeatherMap, GPT-4o-mini, and Discord
This workflow provides an automated, intelligent solution for global weather monitoring. It goes beyond simple data fetching by calculating a custom "Comfort Index" and using AI to provide human-like briefings and activity recommendations. Whether you are managing remote teams or planning travel, this template centralizes complex environmental data into actionable insights.
Who’s it for
  • Remote Team Leads: Keep an eye on environmental conditions for team members across different time zones.
  • Frequent Travelers & Event Planners: Monitor weather risks and comfort levels for multiple destinations simultaneously.
  • Smart Home/Life Enthusiasts: Receive daily morning briefings on air quality and weather alerts directly in Discord.
  1. Schedule Trigger: The workflow runs every 6 hours (customizable) to ensure data is up to date.
  2. Data Collection: It loops through a list of cities, fetching current weather, 5-day forecasts, and Air Quality Index (AQI) data via the OpenWeatherMap node and HTTP Request node.
  3. Smart Processing: A Code node calculates a "Comfort Index" (based on temperature and humidity) and flags specific alerts (e.g., extreme heat, high winds, or poor AQI).
  4. AI Analysis: The OpenAI node (using GPT-4o-mini) analyzes the aggregated data to compare cities and recommend the best location for outdoor activities.
  5. Conditional Routing: An If node checks for active weather alerts. Urgent alerts are routed to a specific Discord notification, while routine briefings are sent normally.
  6. Archiving: All processed data is appended to Google Sheets for historical tracking and future analysis.
How to set up
  1. Credentials: Connect your OpenWeatherMap, OpenAI, Discord (Webhook), and Google Sheets accounts.
  2. Locations: Open the 'Set Monitoring Locations' node and edit the JSON array with the cities, latitudes, and longitudes you wish to track.
  3. Google Sheets: Configure the 'Log to Google Sheets' node with your specific Spreadsheet ID and Sheet Name.
  4. Discord: Ensure your Webhook URL is correctly pasted into the Discord nodes.
Requirements
  • OpenWeatherMap API Key (Free tier is sufficient).
  • OpenAI API Key (Configured for GPT-4o-mini).
  • Discord Webhook URL.
  • Google Sheet with headers ready for logging.
How to customize
  • Adjust Alert Thresholds: Modify the logic in the 'Process and Analyze Data' Code node to change what triggers a "High Wind" or "Extreme Heat" alert.
  • Refine AI Persona: Edit the System Prompt in the 'AI Weather Analysis' node to change the tone or focus of the weather briefing.
  • Change Frequency: Adjust the Schedule Trigger to run once a day or every hour depending on your needs.
