Sync contacts two-way between Zoho CRM and KlickTipp
Created by: KlickTipp || KlickTipp
KlickTipp
Last update a month ago
Categories
Community Node Disclaimer: This workflow uses KlickTipp community nodes.
Introduction
This workflow creates a complete two-way synchronization between KlickTipp and Zoho CRM.
Whenever a contact is created, updated or deleted in either system, the workflow mirrors these changes across both platforms — ensuring your CRM and email marketing database always stay aligned.
Perfect for teams who want automatic, real-time syncing of customer profiles, subscription states, and segmentation data, without manual updates or CSV imports.
Zoho CRM → KlickTipp:
Triggered via Zoho CRM workflow webhooks:
  • Contact registered via Form → creates in KlickTipp → saves KlickTipp Contact ID and status back into Zoho.
  • Contact Created/Updated → routes by subscription → creates or updates in KlickTipp → saves KlickTipp Contact ID and status back into Zoho → Fetches full Zoho contact → Tags contacts.
  • Contact Deleted → Removes the corresponding contact in KlickTipp.
KlickTipp → Zoho CRM:
Triggered by incoming KlickTipp webhooks or specific tags:
  • Contact Tagged in KlickTipp -> Creates or updates contacts in Zoho CRM using KlickTipp data → saves Zoho CRM Contact ID inside KlickTipp → Fetches contact data from KlickTipp for tagging → Tags Zoho CRM Contacts.
  • Contact Deleted in KlickTipp → Removes the corresponding contact in Zoho CRM.
Setup Instructions
  1. KlickTipp Preparation
    • Create custom fields for:
      • Zoho | Contact ID
    • Create tags:
      • Zoho | Send contact
      • Zoho | Contact created
      • Zoho | Contact created via Form
      • Zoho | Online store
      • Zoho | ABC
      • Any additional segmentation tags.
    • Add webhooks:
      • Activation tags: Zoho | Send contact, Zoho | Send deleted contact
      • Activation URLs: webhook URLs from triggers
  2. Zoho CRM Preparation
    • Create workflow rules for:
      • Contact created via form → webhook
      • Contact created or updated → webhook
      • Contact deleted → webhook
    • Create custom fields in Zoho CRM:
      • KlickTipp ID
  3. Credential Configuration
    • Connect your Zoho CRM account using a Client ID and Client Secret from the Zoho API console.
    • Authenticate your KlickTipp connection with username/password credentials (API access required).
Customization
  • Expand mapping nodes to include more Zoho/KlickTipp fields.
  • Add more segmentation branches in the "Check relevant Segment" rule or use other fields for segmentation.
