Generate AI images via Telegram with WaveSpeed, credit system, PIX and S3
Last update a month ago
🤖 Generate images via Telegram using an AI bot with a credit system and S3 storage
A complete, production-ready Telegram bot for AI-powered image generation and editing, featuring a built-in credit system, payment integration, and cloud storage.
✨ Features
🎨 AI Image Generation
  • Text-to-Image: Generate stunning images from text prompts using the Nano Banana Pro Ultra model via WaveSpeed API
  • Image-to-Image Editing: Edit existing images by sending a photo with a caption describing the desired changes
  • Multiple Resolutions: Support for both 4K and 8K output quality
  • Flexible Aspect Ratios: Choose from 10 different aspect ratios (1:1, 3:2, 2:3, 3:4, 4:3, 4:5, 5:4, 9:16, 16:9, 21:9)
💳 Credit Management System
  • Per-generation billing: Different costs for 4K vs 8K resolution
  • Balance tracking: Real-time credit balance displayed to users
  • Initial credits: New users receive starter credits automatically
  • Insufficient balance handling: Graceful messages when credits run out
Here's the adjusted payment section:
💰 Payment Integration (Mercado Pago PIX)
About PIX: PIX is Brazil's instant payment system, launched by the Central Bank of Brazil in 2020. It allows instant money transfers 24/7, 365 days a year, using QR codes or copy-paste codes. It has become the most popular payment method in Brazil due to its speed and zero fees for individuals.
This workflow includes a fully integrated PIX payment flow as a reference implementation. You can adapt it to your local payment provider.
Features:
  • Multiple deposit options: Pre-configured credit packages (R$ 3, R$ 6, R$ 10)
  • QR Code generation: Automatic PIX QR code sent directly to users via Telegram
  • Copy-paste code: PIX code provided for manual payment
  • Webhook confirmation: Real-time payment status updates via Mercado Pago webhooks
  • Auto credit top-up: Credits added automatically upon payment approval
  • Payment status handling: Supports approved, pending, and rejected states
💡 Tip: To adapt this for other regions, replace the Mercado Pago nodes with your preferred payment gateway (Stripe, PayPal, etc.) while keeping the same credit update logic.
⚙️ User Configuration
  • Resolution settings: Users can set their preferred default resolution
  • Aspect ratio preferences: Save preferred aspect ratio for future generations
  • Custom default prompts: Set a default prompt that's automatically appended to all generations
  • Persistent settings: All preferences stored in n8n Data Tables
📦 Cloud Storage (S3/MinIO)
  • Automatic upload: Generated images are automatically uploaded to S3-compatible storage
  • Persistent URLs: Images remain accessible via permanent links
  • Edit from storage: Reference previously uploaded images for editing
🛠️ Tech Stack
Component Technology
Bot Platform Telegram Bot API
AI Generation WaveSpeed API (Nano Banana Pro)
Storage S3-compatible (MinIO/AWS S3)
Database n8n Data Tables
Payments Mercado Pago PIX
Automation n8n
📋 Prerequisites
Before using this workflow, you'll need:
  1. Telegram Bot Token - Create a bot via @BotFather
  2. WaveSpeed API Key - Sign up at WaveSpeed
  3. S3-compatible Storage - MinIO, AWS S3, or any S3-compatible service
  4. Mercado Pago Account (optional) - For payment integration
  5. n8n Data Table - Create a table with the required schema
📊 Data Table Schema
Create a Data Table with the following columns:
Column Type Description
chat_id String Telegram chat ID (primary key)
username String Telegram username
status String Current user state in the flow
credits String User's credit balance
resolution String Preferred resolution (4k/8k)
aspect_ratio String Preferred aspect ratio
user_default_prompt String Custom default prompt
number_images Number Total images generated
number_videos Number Total videos generated
demo_sended Boolean Welcome demo sent flag
⚡ Quick Setup
  1. Import the workflow into your n8n instance
  2. Configure the Global Environment node with your settings:
    • botName: Your bot's display name
    • botToken: Your Telegram bot token
    • dataTableId: Your n8n Data Table ID
    • bucketName: Your S3 bucket name
    • initialCredits: Credits given to new users
    • generateImageCost4k: Cost per 4K image
    • generateImageCost8k: Cost per 8K image
  3. Set up credentials:
    • Telegram API credentials
    • WaveSpeed API credentials
    • S3 credentials
    • Mercado Pago credentials (if using payments)
  4. Activate the workflow
🎮 Bot Commands
Command Description
/start Initialize bot and receive welcome message
menu Return to main menu
config Open settings menu
Any text Generate image from prompt (when in generation mode)
Photo + caption Edit the photo based on the caption
🔄 Workflow Flow
User Message → Telegram Trigger → Route by Status
              New User            Generate Image       Edit Image
             Welcome Flow        Check Credits        Check Credits
            Create User         Submit to WaveSpeed    Upload to S3
             Show Menu           Poll for Result      Submit Edit
                                 Download Image      Poll for Result
                                 Send to User ←←←←←←←←←←←←←┘
📝 Notes
  • The workflow uses polling to check generation status - WaveSpeed processes may take up to 1 minute
  • Credits are deducted when the task is submitted and refunded if generation fails
  • All user states are managed through the Data Table for persistence across restarts
📄 License
Free to use and modify. Attribution appreciated but not required.
