Repurpose LinkedIn posts into X tweets with Apify, Claude AI and Airtable
Created by: Elodie Tasia || ladypixl
Elodie Tasia
Last update a month ago
Automatically scrape LinkedIn posts with Apify, transform them into optimized tweets and threads using Claude AI, store them in Airtable for approval, and publish to X on a daily schedule.
Who is this for
This workflow is designed for content creators, social media managers, and personal brand builders who want to maximize their content reach by repurposing LinkedIn posts for X (Twitter) without manual rewriting.
What it does
This workflow automates the entire LinkedIn-to-X content repurposing pipeline:
  1. Weekly scraping: Uses Apify to scrape your recent LinkedIn posts based on configurable parameters stored in Airtable
  2. Carousel extraction: If a post contains a carousel/PDF, OpenAI extracts the slide content via OCR
  3. AI transformation: Claude (via OpenRouter) converts each LinkedIn post into two X-optimized variations: a standalone tweet and a thread (3-7 tweets)
  4. Content storage: Saves both the original posts and generated tweets to Airtable with a "Pending" status for review
  5. Scheduled publishing: Daily at 12:30, searches for ‘Approved’ tweets whose publication date has passed and posts them to X
  6. Thread handling: Properly chains thread tweets as replies to maintain the conversation structure
Requirements
  • Apify account (LinkedIn Profile Posts Scraper actor)
  • Airtable account with configured base
  • OpenAI API access (for carousel OCR)
  • OpenRouter API access (for Claude)
  • X/Twitter API access
How to set up
  1. Create an Airtable base with three tables: Config, LK Posts, and X Tweets (see table configurations below)
  2. Configure the Config table with your LinkedIn profile URL, scraping limits, and tweet scheduling delay
  3. Configure the ‘TWEET NOW’ button in Airtable with the following URL formula: "https://your-n8-server-url/webhook/post-tweet?id="&RECORD_ID()
  4. Connect your credentials: Apify, Airtable, OpenAI, OpenRouter, and X/Twitter
  5. Set the weekly and daily schedule triggers according to your timezone
  6. Activate the workflow
Config Table
Field Name Type Description
Name String Configuration parameter name
Type Single Select Data type indicator: String, Integer
String Value String Value when Type is "String"
Integer Value Number Value when Type is "Integer"
Configuration parameters to create:
  • profile_url — LinkedIn profile URL to scrape
  • posted_limit — Time range for scraping (possible values: "any", "1h", "24h", "week", "3months", "6months", "year")
  • max_posts — Maximum number of posts to scrape
  • schedule_tweets_days_after_lk — Number of days after LinkedIn post date to schedule the tweet
LK Posts Table
LK Post ID String LinkedIn post unique identifier
Status Single Select Post processing status: Scrapped, Converted, Tweeted
Date DateTime Original LinkedIn post publication date
Content Long Text LinkedIn post text content
Post URL URL Link to the original LinkedIn post
Post Img URL URL URL of post image (if any)
Post Doc URL URL URL of carousel/PDF document (if any)
Carousel Content Long Text Extracted text content from carousel slides
X Tweets Table
Unique ID Formula Auto-generated unique identifier
LK Post ID String Reference to the source LinkedIn post
Status Single Select Tweet status: Pending, Approved, Rejected, Tweeted
Variation Single Select Tweet format: Standalone, Thread
Tweet Nb Number Tweet position in thread (0 for standalone, 1-7 for thread tweets)
Content Long Text The tweet text content
Publication Date DateTime Scheduled date/time to publish the tweet
Post Now Button Triggers webhook to post immediately
How to customize
  • AI prompt: Edit the "ConvertPostIntoTweets" node to adjust tone and style
  • LLM model: Replace the OpenRouter node with OpenAI or any other LLM node in "ConvertPostIntoTweets" if you prefer a different model
  • Posting delay: Change schedule_tweets_days_after_lk in the Config table
  • Schedule: Modify "Weekly_OnSunday" and "Daily_AtNoon" triggers
  • Scraping: Adjust max_posts and posted_limit in Config table
