Scrape high-engagement LinkedIn posts and auto-post with Gemini images
Created by: Roshan Ramani || rawsun007
Roshan Ramani
Last update a month ago
Who's it for
This workflow is ideal for:
  • Content creators who want to replicate successful LinkedIn strategies
  • Social media managers monitoring competitor content performance
  • Marketing teams analyzing trending topics in their industry
  • Personal brands looking to create data-driven content
  • Agencies managing multiple LinkedIn accounts
What it does
This comprehensive workflow automates the entire LinkedIn content lifecycle: it scrapes viral posts from target accounts, analyzes engagement patterns, identifies trending topics, generates original AI-powered content based on those trends, creates accompanying images, and automatically publishes to your LinkedIn profile or company page.
Phase 1: Data Collection (Runs every 12 hours)
  • Scheduler triggers the workflow twice daily
  • Fetches LinkedIn profile URLs from Google Sheets
  • Processes profiles in batches of 3 to respect API limits
  • Uses Apify API to scrape recent posts from each profile
  • Adds 3-second delays between requests to avoid rate limiting
  • Filters for high-engagement posts (20+ likes, comments, or reposts)
  • Saves viral posts to Google Sheets with full metadata
Phase 2: Content Generation (Triggered by new data)
  • Monitors Google Sheets for new viral posts every minute
  • Filters posts published within the last 3 days that haven't been analyzed
  • Aggregates trending content into a single dataset
  • Analyzes patterns using Google Gemini AI to identify:
    • Common themes and topics
    • Engagement triggers and hooks
    • Successful content structures
    • Trending hashtags and formats
  • Generates original LinkedIn post with proper formatting
  • Creates AI image prompt optimized for minimal text
  • Generates professional image using Google Imagen
  • Publishes complete post to your LinkedIn account
  • Marks analyzed posts as complete to prevent duplication
Setup steps
1. Configure Google Sheets
  • Create a new Google Sheet with two tabs:
    • Tab 1: "usernames & links" - Add LinkedIn profile URLs you want to monitor
    • Tab 2: "scrape data" - Leave empty (auto-populated by workflow)
  • Connect your Google Sheets credentials in both nodes
  • Replace all instances of YOUR_GOOGLE_SHEET_ID with your actual sheet ID
  • Replace SHEET_GID values with your actual sheet GIDs
2. Set up Apify API
  • Sign up for Apify account and get API token
  • Replace YOUR_APIFY_API_TOKEN in "Scrape LinkedIn Posts API" node
  • Note: Apify has free tier with limited requests
3. Configure Google Gemini credentials
  • Obtain Google PaLM API credentials
  • Add credentials to both "Google Gemini Chat Model" and "Generate an image" nodes
4. Set up LinkedIn publishing
  • Connect your LinkedIn credentials in "Publish to LinkedIn" node
  • If posting as organization, replace YOUR_LINKEDIN_ORGANIZATION_ID with your company page ID
  • If posting as individual, change "postAs" parameter to "person"
5. Configure scheduling
  • Default schedule: every 12 hours
  • Adjust "LinkedIn Content Automation Scheduler" trigger if needed
  • Consider your API rate limits when changing frequency
6. Test the workflow
  • Manually trigger Phase 1 to scrape posts
  • Verify data appears in Google Sheets "scrape data" tab
  • Wait for Phase 2 trigger or manually activate it
  • Check that content is generated and published correctly
  • Verify posts are marked as analyzed in Google Sheets
Requirements
  • Google Sheets API access (free)
  • Google Sheets Trigger OAuth2 (free)
  • Apify API token (free tier available, $49/month for more)
  • Google PaLM/Gemini API key (pay-per-use pricing)
  • LinkedIn OAuth credentials (free)
How to customize
Adjust scraping targets:
  • Add more LinkedIn profile URLs to your Google Sheets
  • Change batch size in "Process Profiles in Batches" (default: 3)
  • Modify post limit per profile in Apify API call (default: 1 post)
Modify engagement filters:
  • Edit "Filter High-Engagement Posts" node thresholds
  • Default: 20+ likes OR 20+ comments OR 20+ reposts
  • Adjust based on your niche's typical engagement rates
  • Add additional criteria like views or impressions
Customize content analysis window:
  • Change "Filter Recent Posts (3 Days)" to analyze different timeframes
  • Options: 24 hours for fast-moving trends, 7 days for broader patterns
  • Balance between recency and data volume
Refine AI content generation:
  • Edit system prompt in "LinkedIn Content Strategy AI" node
  • Adjust content length, tone, or style preferences
  • Add industry-specific guidelines
  • Include brand voice requirements
  • Modify hashtag strategy
Customize image generation:
  • Edit image prompt structure in AI prompt
  • Change visual style, colors, or composition
  • Adjust for brand guidelines
  • Modify dimensions or aspect ratios
Change posting schedule:
  • Adjust "LinkedIn Content Automation Scheduler" frequency
  • Consider optimal posting times for your audience
  • Balance between content quality and posting frequency
  • Coordinate with other marketing activities
Enhance data collection:
  • Increase posts per profile in Apify settings
  • Add more profile URLs to monitor
  • Implement competitor tracking
  • Track additional metrics like impressions or click-through rates
Add notifications:
  • Connect Slack/Email nodes after successful posts
  • Set up alerts for high-performing content
  • Create reports of analyzed trends
  • Monitor API usage and errors
