Sync contacts, consent, and segments between KlickTipp and Pipedrive
Created by: KlickTipp || KlickTipp
KlickTipp
Last update 25 days ago
Categories
Community Node Disclaimer
This workflow uses KlickTipp community nodes, available for self-hosted n8n instances only.
Who’s it for
Sales and marketing teams using Pipedrive (Persons) and KlickTipp who want a reliable two-way sync for:
  • Contact profiles (name, email, phone, birthday)
  • Consent/marketing status (subscribed / no consent / unsubscribed)
  • Segmentation (KlickTipp Tags ↔ Pipedrive Labels)
This workflow is ideal if you want to avoid CSV imports, prevent manual updates, and ensure that changes in either platform are reflected in the other — including deletes and consent changes.
This workflow creates a complete two-way synchronization between KlickTipp and Pipedrive (Persons).
Whenever a Person is created, updated, unsubscribed, segmented, or deleted in either system, the workflow mirrors these changes across both platforms — so your CRM and email marketing database always stay aligned.
It is designed for near real-time syncing of contact data, consent state, and segmentation (Tags ↔ Labels), without manual work.
KlickTipp → Pipedrive
Triggered by KlickTipp webhooks / activation tag events via “Contact tagged in KlickTipp”:
  1. Fetch contact details in KlickTipp (Get contact data for tagging) to access tags and custom fields.
  2. Route by contact state (Check subscription):
    • Person does not exist (no stored Pipedrive ID in KlickTipp) and contact is not UnsubscribedCreate a person in Pipedrive.
    • Person exists and contact is not UnsubscribedUpdate a person in Pipedrive.
    • Person exists → unsubscribeUpdate a person and set marketing_status = unsubscribed.
  3. Write the Pipedrive Person ID back to KlickTipp (Add Pipedrive Person ID to KlickTipp contact) to permanently link both records.
  4. Sync consent status:
    • KlickTipp status = Subscribed → Pipedrive marketing_status = subscribed
    • Otherwise → marketing_status = no_consent
  5. Sync birthday safely (timezone-aware):
    • KlickTipp birthday is stored as Unix seconds and converted to YYYY-MM-DD using Europe/Berlin timezone to avoid CET/CEST shifts.
  6. Segmentation: KlickTipp Tags → Pipedrive Labels:
    • Reads KlickTipp tags (Check relevant segment) and assigns Pipedrive label IDs via PATCH:
      • Tag 14054258 → Label 14 (Customer)
      • Tag 14054294 → Label 27 (ABC)
Pipedrive → KlickTipp
Triggered by the Pipedrive Person webhook via “Changes in Pipedrive”:
  1. Fetch the current marketing status (Get marketing status) to decide which consent action to apply in KlickTipp.
  2. Route by sync scenario (Check subscription1):
    • Single Opt-In
      If no linked KlickTipp ID exists yet and status is not unsubscribed → create contact in KlickTipp via SOI (Create contact with SOI).
    • Form submission → DOI
      If change_source = api → create contact in KlickTipp via DOI (Create contact with DOI).
    • Update only
      If linked KlickTipp ID exists and status is not unsubscribed → update the existing KlickTipp subscriber (Update contact changes in KlickTipp).
    • Unsubscribe and update
      If linked KlickTipp ID exists and status is unsubscribed → unsubscribe the contact (Unsubscribe contact) and then update core fields (Update contact changes in KlickTipp1).
    • Contact deletion
      If action is delete → delete the KlickTipp contact using the previous email (Delete contact) to remain safe even if the email changed before deletion.
  3. UI-only filtering for SOI path
    • Filter non UI events and deletions ensures the SOI create path processes only UI-driven events (change_source = app) and ignores deletions.
  4. Sync birthday safely (no day shifting)
    • Reads Pipedrive birthday as YYYY-MM-DD from a custom field and converts it to Unix seconds using "T00:00:00Z" to prevent timezone-related day shifts.
  5. Segmentation: Pipedrive Labels → KlickTipp Tags
    • Reads label_ids from Pipedrive (supports array or comma-separated string), normalizes them, then applies tags in KlickTipp (Check relevant segment2):
      • Label 14 (Customer) → Tag 14054258
      • Label 27 (ABC) → Tag 14054294
GDPR Deletion Requests (KlickTipp → Pipedrive)
Triggered by “Contact deletion request triggered” (when a recipient clicks the data deletion link in an email):
  • Immediately deletes the subscriber in KlickTipp.
  • If a linked Pipedrive Person ID exists (field227685), the workflow:
    • Deletes the corresponding Person in Pipedrive.
  • If no Pipedrive ID exists, only the KlickTipp record is removed.
This ensures full GDPR-compliant data removal across both systems.
How to set up
  1. Install the KlickTipp community node in your self-hosted n8n instance.
  2. Create credentials in n8n for:
    • KlickTipp API
    • Pipedrive API (token or OAuth)
  3. In KlickTipp, create a custom field to store the Pipedrive reference:
    • Example used here: Pipedrive | Person ID (mapped as field227685)
  4. In Pipedrive (Person), create custom fields to store:
    • KlickTipp Contact ID (stored via Pipedrive custom properties)
    • Birthday (optional, if you want birthday sync)
  5. Configure your segmentation mapping:
    • Ensure Pipedrive Labels exist and note their IDs (e.g. 14 = Customer, 27 = ABC)
    • Ensure KlickTipp Tags exist and note their IDs (e.g. 14054258, 14054294)
  6. Test both directions:
    • Add a tag in KlickTipp → confirm the Person is created/updated in Pipedrive and labels are assigned.
    • Update a Person in Pipedrive → confirm the subscriber is created/updated/unsubscribed in KlickTipp accordingly.
  7. Activate the workflow.
💡 Pro Tip: Start testing with a single contact and one label/tag mapping first, then expand to more fields and segments.
Requirements
  • Self-hosted n8n instance (community nodes supported)
  • KlickTipp account with API access
  • Pipedrive account with API access
  • Pipedrive Person webhook enabled (create/update/delete events)
  • KlickTipp webhook/activation tag configured to trigger the KlickTipp side
How to customize
  • Add more field mappings (organization, address, custom properties, owner).
  • Extend segmentation rules (more labels/tags, deal-based logic, pipeline-specific tags).
  • Adjust SOI/DOI routing (e.g., force DOI for certain sources or segments).
  • Add audit logging (Google Sheets, database, or Slack alerts on errors).
  • Add safeguards (e.g., skip contacts without email, handle duplicates with additional lookup logic).
