Publish LinkedIn posts from tech trends with Ollama AI quality checks
Created by: Tony Adijah || togo
Tony Adijah
Last update a month ago
Who is this for?
This workflow is for solopreneurs, founders, creators, and marketers who want a consistent LinkedIn presence without spending hours writing posts. Ideal for anyone in tech, SaaS, or AI who wants trend-aware content on autopilot.
What it does
Flow 1 — Daily Research (6 AM):
  • Fetches trending topics from Hacker News, Reddit (8 subreddits), and Product Hunt in parallel
  • Merges all sources, runs 7-layer deduplication, and ranks by relevance
  • AI generates 3 LinkedIn post drafts with different angles
  • Saves all drafts to a Google Sheets queue with status tracking
Flow 2 — Smart Publish (Tue/Wed/Thu at 9:30 AM):
  • Reads all unpublished drafts from Google Sheets
  • AI Selector picks the single best draft for today
  • Selected post passes through an AI Quality Gate (scored 1–10)
  • Approved posts publish to LinkedIn with a hashtag comment
  • Posts needing revision get auto-rewritten, then published
  • Rejected posts are skipped; Telegram notifications on every action
Setup steps
  1. Google Sheets — Create a spreadsheet with columns: Post ID, Angle, Hook Line, Full Post, Hashtags, Trend Referenced, Word Count, Best Day, Posting Notes, Status, Created Date, Published Date, LinkedIn URL, AI Review, Revised Post, Dedup Stats, Generated At
  2. Ollama — Install locally and pull your preferred model (e.g., ollama pull mistral)
  3. LinkedIn OAuth — Register an app at developer.linkedin.com with w_member_social scope, get your Person URN
  4. Telegram Bot — Create via @BotFather, get your bot token and chat ID
  5. AI Prompts — Edit the system prompts in AI Writer, AI Selector, and AI Quality Gate nodes to match your persona and brand voice
  6. Test — Run the research flow manually first, verify drafts appear in your sheet, then test the publish flow
Requirements
  • Self-hosted n8n (uses Ollama nodes)
  • Ollama running locally with at least one model installed
  • Google Sheets OAuth2 credentials
  • LinkedIn OAuth2 credentials with w_member_social permission
  • Telegram Bot credentials
How to customize
  • Tweak AI Selector weights in its system prompt (day alignment, angle variety, engagement potential)
  • Adjust Quality Gate thresholds (hook strength, value density, authenticity, engagement, brand safety)
  • Set any draft status to force_publish in Google Sheets to override AI selection
  • Add more sources by duplicating the fetch/normalize pattern
  • Change posting schedule by editing the cron expressions in the Schedule Trigger nodes
