Create and publish AI social posts to multiple platforms using Blotato
Created by: Dr. Firas || drfiras
Dr. Firas
Last update a month ago
AI-Powered Social Media Content Factory (Blotato × n8n)
📄 Documentation: Notion Guide
Workflow Overview
This n8n template automates the end-to-end creation, validation, approval, and publishing of social media content from a single YouTube link or text input, using AI-powered transcription, fact-checking, visual generation, and multi-platform publishing. :contentReference[oaicite:0]{index=0}
Who is this for?
This workflow is designed for:
  • Content creators and educators
  • Social media managers and agencies
  • Solo founders and marketers
  • Anyone producing short-form content at scale (Instagram, TikTok, Twitter/X, LinkedIn, Facebook)
It is especially useful if you want to turn long-form videos into high-quality social posts automatically.
What problem is this workflow solving? / Use case
Creating consistent, accurate, and visually engaging content across multiple platforms is:
  • Time-consuming
  • Repetitive
  • Error-prone (especially with AI hallucinations)
This workflow solves that by:
  • Automating transcription from YouTube
  • Verifying content with Perplexity AI
  • Generating multiple visual formats automatically
  • Adding a human-in-the-loop approval step via Telegram
  • Publishing to multiple platforms in one flow
What this workflow does
  1. Trigger via Telegram
    • Send a YouTube URL or text message to start the workflow.
  2. AI Transcription
    • Extracts and transcribes the full video content.
    • Returns the video title and clean transcript.
  3. Fact-checking & Summarization
    • Uses Perplexity AI to validate information.
    • Generates a concise, structured summary (bullet points).
  4. Dynamic Template Selection (Switch Node)
    Automatically routes content to one of several visual formats:
    • Tweet-style carousel (minimal design)
    • AI video with AI voice
    • Image slideshow with prominent text
    • Breaking news–style video
    • Tutorial carousel with monocolor background
  5. AI Visual Generation (Blotato)
    • Generates images or videos based on the selected template.
    • Supports vertical, square, and feed-friendly formats.
  6. Approval via Telegram
    • Sends the generated visual for manual approval.
    • Ensures quality control before publishing.
  7. Multi-Platform Publishing
    • Publishes automatically to:
      • Instagram
      • TikTok
      • Facebook
      • LinkedIn
      • Twitter/X
  8. Publishing Confirmation
    • Sends a final “Published” notification via Telegram.
  1. Required accounts & credentials
    • n8n (self-hosted or cloud)
    • Blotato API account
    • Telegram Bot (BotFather)
    • Social media accounts connected in Blotato
  2. Configure credentials in n8n
    • Telegram API credentials
    • Blotato API credentials
  3. Import the workflow
    • Import the provided JSON file into n8n.
    • Activate the workflow.
  4. Telegram usage
    • Send a YouTube link or content to the Telegram bot to trigger the workflow.
How to customize this workflow to your needs
  • Change templates
    Modify or remove visual templates in the Switch node.
  • Adjust AI prompts
    Fine-tune:
    • Transcription instructions
    • Summary depth
    • Visual generation prompts
  • Branding
    • Update profile images, author names, handles, and colors.
    • Customize CTA text per platform.
  • Platform selection
    • Disable platforms you don’t use.
    • Duplicate posting logic for additional accounts.
  • Approval logic
    • Skip approval for full automation.
    • Add rejection or revision flows if needed.
🎥 Watch This Tutorial
SORA2 logo
👋 Need help or want to customize this?
📩 Contact: LinkedIn
📺 YouTube: @DRFIRASS
🚀 Workshops: Mes Ateliers n8n
Need help customizing?
Contact me for consulting and support : Linkedin / Youtube / 🚀 Mes Ateliers n8n
