Capture vCard QR code contacts with AllCodeRelay and add them to KlickTipp
Created by: KlickTipp || KlickTipp
KlickTipp
Last update a month ago
Categories
Community Node Disclaimer: This workflow uses KlickTipp community nodes.
Introduction
This workflow captures vCard contact data from a scanned QR code using AllCodeRelay and automatically creates a contact in KlickTipp. It is built for event lead capture and fast contact transfer: scan a vCard QR code, send the scan result to a webhook, parse the vCard into clean contact fields, and submit the contact to KlickTipp with Double Opt-In (DOI).
This template is ideal for marketers, sales teams, and event staff who want a frictionless way to digitize business cards and subscribe contacts into KlickTipp in real time.
  1. Trigger: Scan Webhook from AllCodeRelay
    • AllCodeRelay sends the scan payload to an n8n webhook endpoint.
  2. Filter: vCard Only
    • Only payloads containing a valid vCard are processed (e.g., BEGIN:VCARD ... END:VCARD).
  3. Parse: vCard → Contact Fields
    • Extracts and normalizes these fields for mapping:
      • firstName, lastName, email, mobile, fax, phone
      • company, position
      • street, city, state, zip, country
      • website
  4. KlickTipp: Add Contact with DOI
    • Creates or updates the subscriber and triggers DOI.
Setup Instructions
  1. AllCodeRelay configuration
    • Install AllCodeRelay on your phone.
    • Create a webhook destination pointing to the n8n webhook URL from Step 2.
    • Scan a static vCard QR code.
  2. n8n configuration
    • Open the first node (Webhook) and copy the Test URL (or Production URL after publishing).
    • In AllCodeRelay, paste the URL as the webhook target.
    • Run a test scan and verify that the workflow receives BEGIN:VCARD payloads.
  3. KlickTipp configuration
    • Create a segmentation tag (e.g., vCard QR code scan)
    • Authenticate your KlickTipp connection with username/password credentials (API access required).
    • Map the parsed fields to the "KlickTipp: Add Contact with DOI" node.
    • Select DOI opt-in process and tag "vCard QR code scan".
Notes
  • This template supports vCard QR codes where the QR content is the vCard text itself (static/offline vCard).
  • If your QR code resolves to a short URL (dynamic QR), the scan will only return the URL and will not contain embedded vCard data.
  • Extend parsing to support additional vCard fields if needed (e.g., multiple emails, additional addresses).
