Resolve and create KlickTipp tags from names with optional prefixes
Created by: KlickTipp || KlickTipp
KlickTipp
Last update 23 days ago
Categories
Community Node Disclaimer
This workflow uses KlickTipp community nodes, available for self-hosted n8n instances only.
Introduction
This workflow receives an array of tag names, optionally applies a prefix to all tags, checks which tags already exist in KlickTipp, creates the missing ones, and returns a unified array of resolved tag names. This allows you to reuse the same get or create tags logic across multiple automations without duplicating tag-handling logic.
It’s especially useful when tags are namespaced by a tool or source (for example, Zoho | Webinar) and you want to enforce consistent tagging conventions across different workflows.
  • Accepts input:
    • tagNames[] — array of base tag names
    • prefix — optional string applied to all tag names
  • Splits tagNames[] into individual items and builds the final tag name:
    • If prefix is provided → prefix tagName (e.g. Zoho | Webinar)
    • If prefix is empty → tagName (e.g. Webinar)
  • Loads the existing KlickTipp tags and matches them by name.
  • Creates tags that do not yet exist.
  • Combines existing and newly created tags.
  • Returns a single aggregated array of resolved tag names, without duplicates.
Setup Instructions
1) Credentials
  • Configure your KlickTipp credentials in the KlickTipp nodes.
2) How to call this sub-workflow
From a parent workflow, use an Execute Sub-workflow node and pass:
Without prefix
  "tagNames": ["Webinar", "Newsletter]
With prefix
  "prefix": "Zoho | ",
  "tagNames": ["Webinar", "Newsletter"]
Resulting tag names resolved or created in KlickTipp:
  • Zoho | Webinar
  • Zoho | Newsletter
Output
Returns a unified array of tag names:
  "tags": ["Zoho | Webinar", "Zoho | Newsletter"]
Testing
  • Test with a mix of existing and new tag names.
  • Confirm new tags appear in KlickTipp when missing.
  • Verify that the output contains all expected tag names, without duplicates.
  • If a prefix is used, ensure tags are resolved or created under the correct namespace (for example, Zoho | …).
  • Reuse the returned tags[] in downstream workflows (for example, for filtering, comparison, or further tagging logic).
