Detect and isolate ransomware with Claude (Anthropic), EDR, SIEM and Slack
Last update 21 days ago
This workflow provides real-time detection of ransomware encryption patterns using Claude AI, with automated system isolation and incident response.
  1. File System Monitoring - Continuously monitors file operations (create, modify, rename, delete) across critical directories
  2. Behavior Pattern Collection - Aggregates file operation metrics in 30-second windows (entropy changes, extension changes, I/O velocity)
  3. AI Threat Analysis - Claude AI analyzes patterns against known ransomware behaviors (mass encryption, shadow copy deletion, etc.)
  4. Threat Scoring & Classification - Assigns threat scores (0-100) and classifies attack types (crypto-locker, wiper, etc.)
  5. Auto-Isolation Decision - Determines if immediate network isolation is required based on confidence thresholds
  6. System Quarantine - Executes automated isolation: disable network adapters, block shares, kill suspicious processes
  7. Forensic Snapshot - Captures system state, process tree, network connections, and file operation logs
  8. Incident Response Alert - Notifies SOC team with detailed threat intelligence and recommended actions
  9. Evidence Preservation - Stores forensic data and AI analysis in SIEM for investigation
Detection Capabilities
  • Entropy Analysis: Detects high-entropy file creation (encrypted data signature)
  • Extension Scanning: Identifies suspicious extension changes (.docx → .locked, .encrypted, .crypted)
  • I/O Velocity: Flags abnormal file modification rates (>100 files/min)
  • Shadow Copy Deletion: Detects vssadmin.exe / wmic.exe shadow copy deletion attempts
  • Ransom Note Detection: Identifies README.txt, HOW_TO_DECRYPT.html creation patterns
  • Lateral Movement: Monitors SMB/RDP connection spikes from infected hosts
  • Process Behavior: Analyzes suspicious parent-child process relationships
Setup Steps
  1. Import workflow into n8n
  2. Configure credentials:
    • Anthropic API - Claude AI for threat analysis
    • Windows Event Collector / Sysmon - File system event source
    • EDR API (CrowdStrike/Defender/SentinelOne) - For isolation commands
    • SIEM API (Splunk/Elastic) - For log forwarding
    • Slack/PagerDuty - For SOC alerts
  3. Install file system watcher on monitored endpoints (sysmon, osquery, or auditd)
  4. Configure isolation thresholds (default: threat_score >= 75)
  5. Test isolation procedure in sandbox environment
  6. Activate workflow
Sample Detection Event
  "hostname": "DESKTOP-WKS-042",
  "username": "jdoe",
  "timestamp": "2025-02-25T14:23:17Z",
  "detection_window_seconds": 30,
  "file_operations": {
    "files_modified": 247,
    "files_renamed": 189,
    "files_created": 58,
    "files_deleted": 31,
    "avg_entropy_increase": 7.89,
    "suspicious_extensions": [".locked", ".crypted", ".encrypted"],
    "ransom_notes_created": ["README_DECRYPT.txt", "HOW_TO_RECOVER.html"]
  "process_activity": {
    "high_io_processes": [
      {"name": "explorer.exe", "pid": 4782, "io_rate": "523 ops/sec"},
      {"name": "svchost.exe", "pid": 2194, "io_rate": "412 ops/sec"}
    "suspicious_commands": [
      "vssadmin.exe delete shadows /all /quiet",
      "wmic shadowcopy delete",
      "bcdedit /set {default} recoveryenabled no"
  "network_activity": {
    "c2_connections": [
      {"ip": "185.220.101.32", "port": 443, "country": "RU"},
      {"ip": "194.165.16.85", "port": 8443, "country": "NL"}
    "lateral_movement": [
      {"target": "FILE-SERVER-01", "protocol": "SMB", "status": "success"},
      {"target": "DB-SERVER-03", "protocol": "RDP", "status": "failed"}
Threat Intelligence Sources
  • MITRE ATT&CK Framework (T1486 - Data Encrypted for Impact, T1490 - Inhibit System Recovery)
  • Known ransomware families: LockBit, BlackCat/ALPHV, Royal, Play, Cl0p
  • File extension IOCs from ransomware tracking feeds
  • Behavioral signatures from recent campaigns
Compliance & Forensics
  • Chain of Custody: All isolation actions logged with timestamps and justifications
  • NIST CSF Alignment: DE.CM-7 (Monitoring for unauthorized activity), RS.MI-3 (Incident containment)
  • Evidence Integrity: Forensic snapshots include cryptographic hashes for court admissibility
  • Post-Incident Review: AI analysis archived for threat hunting and pattern improvement
