Monitor BOAMP IT tenders and score them with GPT-4o Mini to Supabase
Created by: ben daamer || ahmedbendaamer
ben daamer
Last update 21 days ago
• Fetches IT-related tenders from the French BOAMP API (filter: informatique)
• Scores each tender with OpenAI (pertinence, budget, stack, GO/NO-GO)
• Routes to Supabase as hot (≥75) or archived
• Run the SQL from the "Supabase Schema" sticky note in the workflow before use
Set up steps
• Create a Supabase project and run the SQL from the "Supabase Schema" sticky note - ~5 min
• Add OpenAI and Supabase credentials in n8n
• Activate the workflow - runs every 4h, or trigger manually/webhook
