Build, test and deploy AI projects with Windsurf CI/CD and Vercel
Last update 21 days ago
This is a conceptual / starter workflow that triggers on git events (or schedule), runs Windsurf-powered build & test steps (via API or CLI wrapper), builds Docker if needed, pushes to registry, deploys to a target platform (e.g. Vercel / Render example), and notifies.
What’s the Goal?
Provide a no/low-code CI/CD pipeline for AI projects using Windsurf’s AI coding & deployment capabilities inside n8n — no external GitHub Actions / Jenkins needed.
Why Does It Matter?
AI projects evolve rapidly → manual deploy is slow & error-prone. Windsurf + n8n keeps model code, keys & inference private while automating quality gates & deployments.
How It Works
  1. Git webhook / schedule starts flow
  2. Clone latest code
  3. Trigger Windsurf build + test (lint, unit tests, model eval)
  4. If tests pass → build Docker image
  5. Push image to registry
  6. Deploy to target (Vercel / Render / Railway / Fly.io / K8s)
  7. Notify success / failure
Configuration Requirements
  • Git provider webhook / token
  • Windsurf API key or self-hosted runner access
  • Docker registry credentials
  • Deployment target token (Vercel / Render / etc.)
  • Notification (Slack / Email)
Setup Guide
  1. Import workflow
  2. Connect credentials (Git, Windsurf, Docker, Deploy target, Slack)
  3. Configure Set node: repo URL, branch, Windsurf profile, deploy target
  4. Test manually first
  5. Activate webhook → push code to trigger
  6. Monitor & tune failure branches
Contact / support:
https://www.oneclickitsolution.com/contact-us/
