Moderate Facebook group posts with OpenAI, Slack, and Airtable
Created by: WeblineIndia || weblineindia
WeblineIndia
Last update 21 days ago
Facebook Group Auto-Moderation
This workflow automatically monitors Facebook Group posts, analyzes them using AI, detects policy violations, logs incidents, notifies moderators and automatically hides high-severity posts to keep the community clean and safe.
This workflow listens to new Facebook Group posts in real time, processes each post individually and sends the post content to AI for moderation.If a post violates group rules (spam, scam, hate, adult content or aggressive promotion), the workflow alerts moderators, stores the violation in Airtable and automatically hides the post if the severity is high.
You receive:
  • Real-time AI moderation of Facebook Group posts
  • Automatic hiding of high-risk content
  • Slack alerts for moderation actions
  • Airtable logging for audit and tracking
Ideal for Facebook Group admins who want fast, consistent and automated moderation without manual review of every post.
Quick Start – Implementation Steps
  1. Connect the Facebook Group Webhook to your n8n instance.
  2. Add your Facebook Page Access Token as an environment variable.
  3. Connect OpenAI credentials for content moderation.
  4. Configure Slack for alerts and Airtable for logging.
  5. Test using sample Facebook post data.
  6. Activate the workflow.
What It Does
This workflow automates Facebook Group moderation:
  1. Receives new group posts via webhook.
  2. Splits and processes posts one by one.
  3. Normalizes post data (ID, message, user, time).
  4. Sends post content to AI for moderation analysis.
  5. Determines:
    • Violation or not
    • Category (spam, scam, hate, adult, etc.)
    • Severity (low / medium / high)
  6. Logs violations into Airtable.
  7. Sends alerts to Slack.
  8. Automatically hides posts marked as high severity.
  9. Notifies the team whether auto-hide succeeded or failed.
Who’s It For
This workflow is ideal for:
  • Facebook Group admins & moderators
  • Community management teams
  • Social media operations teams
  • Platforms handling large group volumes
  • Anyone needing automated moderation at scale
Requirements to Use This Workflow
To run this workflow, you need:
  • n8n instance (cloud or self-hosted)
  • Facebook Group Webhook subscription
  • Facebook Page Access Token
  • OpenAI API key
  • Slack workspace with API access
  • Airtable base + Personal Access Token
How It Works
  1. Receive Facebook Post – Webhook captures new group posts.
  2. Process Posts – Posts are handled one at a time.
  3. Normalize Data – Extracts clean post and user details.
  4. AI Moderation – AI analyzes the post for rule violations.
  5. Violation Check – Determines whether action is needed.
  6. Severity Check – Only high-risk posts are auto-hidden.
  7. Hide Post – Facebook API hides the post automatically.
  8. Log & Notify – Slack alerts + Airtable records are created.
Setup Steps
  1. Import the workflow JSON into n8n.
  2. Configure the Webhook node and subscribe it to your Facebook Group.
  3. Add FB_PAGE_ACCESS_TOKEN in n8n environment variables.
  4. Connect OpenAI, Slack and Airtable credentials.
  5. Verify Airtable field names match the workflow mapping.
  6. Test using pinned sample data.
  7. Activate the workflow.
How To Customize Nodes
Customize Moderation Rules
Edit the AI Content Moderation node to:
  • Adjust strictness
  • Add or remove categories
  • Change severity logic
Customize Slack Alerts
You can add:
  • Emojis
  • Mentions (@channel / @here)
  • Direct links to the Facebook post
Customize Auto-Hide Logic
Change the Severity High? IF node to:
  • Auto-hide medium severity
  • Disable auto-hide completely
  • Add manual approval steps
Add-Ons (Optional Enhancements)
You can extend this workflow to:
  • Add moderator approval before hiding posts
  • Auto-ban repeat offenders
  • Track user violation history
  • Generate daily moderation summaries
  • Add sentiment analysis
  • Create dashboards using Airtable Interfaces
  • Support multiple Facebook Groups
Use Case Examples
1. Spam Control
Automatically hide promotional or scam posts.
2. Community Safety
Detect hate or adult content instantly.
3. Moderator Efficiency
Reduce manual review workload.
4. Audit & Compliance
Maintain a clear violation history in Airtable.
5. Large Group Management
Scale moderation without adding moderators.
Troubleshooting Guide
Issue Possible Cause Solution
No posts received Webhook not subscribed Verify Facebook webhook setup
AI result missing OpenAI error Check API key & rate limits
Post not hidden Token permission issue Verify Page Access Token permissions
Slack alert not sent Invalid Slack credentials Reconnect Slack API
Airtable error Field mismatch Match Airtable column names exactly
Need Help?
If you need help extending this workflow with multi-group moderation, advanced AI rules, dashboards or production-scale automation, our n8n automation experts at WeblineIndia can assist with custom workflow design and deployment.
