Generate Viral AI Motion Video 🤣🤖 using Kling 2.6 Kie AI & Auto-Post to TikTok
Created by: Davide Boizza || n3witalia
Davide Boizza
Last update 21 days ago
This workflow automates the creation and publishing of AI-generated motion videos for TikTok. The process starts with an image and a reference motion video.
Using the Kling v2.6 Motion Control AI model, the workflow generates a new animated video where the character from the image replicates the movements from the reference video.
Once the AI-generated video is produced, the workflow automatically retrieves the result, uploads it to Postiz, and publishes it directly to TikTok with a predefined caption.
Start: Watch the starting video
Result: Watch the final video
Key Advantages
1. ✅ Full Automation
The workflow automates the entire pipeline from AI video generation to social media publishing, eliminating manual steps.
2. ✅ AI-Powered Content Creation
By leveraging Kling Motion Control, the system creates dynamic animated content from a static image and motion reference video.
3. ✅ Scalable Content Production
This setup enables rapid production of multiple AI-generated videos, making it ideal for automated social media content strategies.
4. ✅ Efficient Asynchronous Processing
The workflow uses webhooks and wait nodes to handle long-running AI jobs efficiently without blocking the workflow.
5. ✅ Seamless Social Media Integration
Direct integration with Postiz and TikTok allows automatic publishing, streamlining the content distribution process.
6. ✅ Modular and Customizable
Each step (AI generation, parsing, upload, publishing) is modular, allowing easy modification for:
  • different AI models
  • other social platforms
  • different prompts or media inputs
7. ✅ Reduced Manual Work
Content creators can generate and publish AI-based videos with a single workflow execution.
  1. Trigger & Input: The workflow is started manually. The initial "Set params" node defines the key inputs: an image_url, a video_url, and a tiktok_desc (caption).
  2. AI Video Generation:
    • The "Run Kling v2.6 Motion Control" node sends a request to the Kie.ai API. It instructs the AI to make the character in the static image follow the movements from the reference video. Crucially, it includes a callBackUrl (the n8n webhook URL from the Wait node) so the API can notify the workflow when the video is ready.
    • The workflow then pauses at the "Wait" node, holding its execution until it receives the callback from Kie.ai.
  3. Retrieve Result: Once the AI finishes processing, it sends a request to the "Wait" node's webhook, which resumes the workflow. The "Result" node then fetches the details of the completed job, including a link to the newly generated video (resultUrl).
  4. Process for Posting:
    • The "Parsing" node extracts the resultUrl from the API's JSON response.
    • A "Get ResulUrl" Code node formats this data to be passed to the next step.
    • The "Get File Video" node uses the resultUrl to download the actual video file from the temporary URL.
  5. Upload & Schedule:
    • The "Upload Video to Postiz" node takes the downloaded video file and uploads it to the Postiz platform using a multipart/form-data request.
    • The final "TikTok" (Postiz) node creates a new post. It uses the video ID returned from the upload and the tiktok_desc from the initial parameters to schedule the post to the specified TikTok integration.
Setup steps
To make this workflow work for you, you need to configure the following:
  1. Set Input Parameters: In the "Set params" node, replace the example image_url, video_url, and tiktok_desc with your own values.
    • image_url: Direct URL to the static character image.
    • video_url: Direct URL to the reference movement video.
    • tiktok_desc: The caption you want for the final TikTok post.
  2. Kie.ai API Credentials:
    • Locate the "Run Kling v2.6 Motion Control" and "Result" nodes.
    • You will need to provide credentials for httpBearerAuth.
    • Replace the existing credential ID with your own Kie.ai API credentials. Ensure the credential is configured with a valid API Bearer Token.
  3. Postiz API Credentials:
    • Locate the "Upload Video to Postiz" node.
    • Provide credentials for httpHeaderAuth.
    • Replace the existing credential ID with your own Postiz API key. This key must be set as a header for authentication.
  4. Postiz Integration ID:
    • In the final "TikTok" (Postiz) node, look for the field integrationId inside the posts.post.value object.
    • Replace the placeholder "XXX" with the actual Integration ID for your TikTok account from Postiz.
👉 Subscribe to my new YouTube channel. Here I’ll share videos and Shorts with practical tutorials and FREE templates for n8n.
Need help customizing?
Contact me for consulting and support or add me on Linkedin.
