Who is this for
Content creators, social media managers, and solopreneurs who want to automate carousel post creation and multi-platform publishing from a single Telegram message.
What this workflow does
This workflow turns a Telegram message or voice note into a fully designed carousel post published simultaneously to Instagram, Facebook, and TikTok. An AI agent drafts quotes and captions, you approve via chat, and the rest happens automatically -- image generation, publishing, and status tracking.
- Telegram input -- Send a topic or idea to the Telegram bot as a text message or voice note.
- Voice transcription -- If a voice note is detected, OpenAI Whisper transcribes it to text.
- AI drafting -- An AI Agent (OpenAI GPT with conversation memory and structured output) generates a short script, 5 carousel quotes, and a social media caption with hashtags.
- Review loop -- The draft is sent back to Telegram. You can request changes -- the agent refines until you approve.
- Data logging -- Approved quotes and the caption are saved to a Google Sheets spreadsheet for reference.
- Image generation -- Each of the 5 quotes is rendered as a styled carousel slide using your APITemplate.io template.
- Multi-platform publishing -- The carousel is posted to Instagram, Facebook (with page selection), and TikTok via Blotato.
- Status monitoring -- Each platform's publish status is polled in a retry loop. You receive a Telegram confirmation on success or an error notification if something fails.
Setup steps
- Telegram Bot -- Create a bot via @BotFather and add the API token as a Telegram credential in n8n.
- OpenAI -- Add your API key as an OpenAI credential. Used for both the AI Agent and Whisper transcription.
- Google Sheets -- Create an OAuth2 credential. Set up a spreadsheet with columns:
run_id, quote1–quote5, social_media_text. Update the Sheet ID and tab in the Google Sheets node.
- APITemplate.io -- Create an account and design a carousel slide template. Set the template ID in the five image generation nodes.
- Blotato -- Connect your Instagram, Facebook, and TikTok accounts in Blotato. Add the Blotato API credential in n8n. Update the account and page IDs in the three publishing nodes.
Requirements
- Community node:
@blotato/n8n-nodes-blotato -- self-hosted n8n only
- OpenAI API key
- Google Sheets OAuth2 credentials
- APITemplate.io account and template
- Blotato account with connected social media profiles
- Telegram Bot token
How to customize
- AI prompt -- Edit the system message in the "AI: Draft & Revise Post" node to change tone, quote count, or output structure.
- Carousel design -- Modify or replace the APITemplate.io template ID to use your own visual design.
- Platforms -- Remove or add publishing nodes if you only need some platforms (e.g., Instagram only).
- Approval flow -- Adjust the approval keywords in the AI prompt (currently: "approved", "ok", "looks good", "ship it").
- Retry timing -- Change the wait durations in the status-check loops to match your preferred polling interval.
