Who is this for
Content creators, solopreneurs, and marketing teams who produce long-form content (podcasts, newsletters, interviews, scripts) and want to automatically turn it into multiple social media assets -- Instagram carousels, LinkedIn carousels, LinkedIn text posts, and LinkedIn media posts -- with human-in-the-loop approval via Microsoft Teams.
What this workflow does
This workflow takes a long-form content file sent via email, extracts strategic content pillars using AI, then fans out into four parallel branches -- each producing a different social media format. Every draft is reviewed and approved in Microsoft Teams before images are generated, assets are saved to Google Drive, and posts are published via Blotato.
- Email trigger -- A Gmail Trigger watches for emails with a specific subject line (e.g. "Content Repurposing"). The email contains a text attachment (podcast transcript, newsletter, etc.) and optionally a link to the original content.
- File extraction & storage -- The attachment is extracted, saved as a Google Doc in a timestamped project subfolder on Google Drive, and the source URL is parsed from the email body.
- AI content strategist -- The Repurpose Strategist agent (OpenAI) analyzes the full text and extracts 5 strategic content pillars, each with a hook headline, core insight, virality factor, and relevant quote. Results are logged in Google Sheets.
- Four parallel content branches -- The 5 pillars feed into four specialized AI agents that each produce a different format:
- Instagram/YouTube carousel -- 5 punchy one-liners (max 25 words each) + a social media caption
- LinkedIn carousel -- 5 slide texts with hooks + a companion caption, plus a styled PDF carousel via HTML-to-PDF
- LinkedIn text post -- A single strong LinkedIn post (max 100 words)
- LinkedIn media post -- A post with a guiding statement rendered as an image
- Human review loop -- Each branch sends its draft to Microsoft Teams for approval via a custom form (approve/reject with feedback). If rejected, feedback is routed back to the AI agent for targeted revisions.
- Asset generation & storage -- On approval, carousel images are generated via APITemplate.io, all assets (images, post texts, PDFs) are saved to organized Google Drive subfolders, and results are logged back to Google Sheets.
- Publishing -- Approved posts are published to Instagram and LinkedIn via Blotato, with status monitoring and Teams notifications on success or failure.
Setup steps
- Gmail -- Create OAuth2 credentials. The trigger watches for emails with "Content Repurposing" in the subject. You can customize this filter.
- Google Drive & Docs -- Create OAuth2 credentials. Set the target folder ID in the Google Drive Trigger node where project subfolders will be created.
- Google Sheets -- Create a spreadsheet to serve as the content tracker. It will store pillars, carousel texts, post texts, and metadata. Update the Sheet ID in all Google Sheets nodes.
- OpenAI -- Add your API key. Used by 5 AI agents (strategist + 4 content specialists).
- Microsoft Teams -- Create OAuth2 credentials. Set the Teams chat ID in the 4 review nodes to route drafts to your approval channel.
- APITemplate.io -- Create an account and design carousel slide templates. Set the template ID in the image generation nodes.
- Blotato -- Connect your Instagram and LinkedIn accounts. Add the Blotato API credential and update account IDs in the publishing nodes.
- HTML-to-PDF -- Install the community node
n8n-nodes-htmlcsstopdf (self-hosted only). Customize the carousel slide HTML/CSS template with your branding (logo, colors, profile photo).
Requirements
- Community nodes:
- Self-hosted n8n only (due to community nodes)
- Gmail OAuth2 credentials
- Google Drive, Docs & Sheets OAuth2 credentials
- OpenAI API key
- Microsoft Teams OAuth2 credentials
- APITemplate.io account and template
- Blotato account with connected Instagram and LinkedIn profiles
How to customize
- AI prompts -- Each of the 5 AI agents has a detailed system prompt you can adjust for tone, word count, language, or output structure.
- Carousel design -- Edit the HTML/CSS in the "HTML to PDF" node to match your brand (colors, fonts, logo, profile photo). Update the APITemplate.io template IDs for Instagram-style slides.
- Platforms -- Add or remove publishing branches. Currently supports Instagram (via Blotato) and LinkedIn (text post, carousel, media post).
- Review channel -- Change the Teams chat ID to route to different teams or channels.
- Trigger -- Swap Gmail for another trigger (e.g. Google Drive, webhook, or manual) depending on your content intake workflow.
- Feedback loop -- Each branch supports unlimited revision cycles. The AI applies feedback minimally without rewriting from scratch.
