AI Handwritten Memo Organizer – Overview
This workflow receives handwritten memo images sent via LINE and automatically extracts, summarizes, and organizes the content using AI.
Step-by-step process:
- User sends a handwritten memo image via LINE
- Webhook receives the image
- Immediate reply is sent: “Processing…”
- Image is saved to Google Drive
- AI performs OCR and generates structured data (title, category, summary, tags)
- The JSON response is safely parsed with error handling
- OCR failure is detected if text cannot be properly extracted
If OCR fails:
→ User is notified with guidance for retaking the image
If OCR succeeds:
→ Check if the category sheet exists in Google Sheets
→ If not, create a new sheet
→ Save the data (title, summary, tags, date, image URL)
- Completion message is sent to the user via LINE
Setup Steps
- Create a LINE Messaging API channel and obtain the Channel Access Token
- Create a Google Spreadsheet for storing memo data
- Create a Google Drive folder to store uploaded images
- Set the following values in the Config node:
o LINE_ACCESS_TOKEN
o GOOGLE_SHEETS_ID
- Set the Webhook URL in the LINE Developers Console
