Build an OpenAI RAG system with document upload, semantic search and caching
Created by: ResilNext || rnair1996
ResilNext
Last update 6 hours ago
Overview
This workflow implements a complete Retrieval-Augmented Generation (RAG) system for document ingestion and intelligent querying.
It allows users to upload documents, convert them into vector embeddings, and query them using natural language. The system retrieves relevant document context and generates accurate AI responses while using caching to improve performance and reduce costs.
This workflow is ideal for building AI knowledge bases, document assistants, and internal search systems.
How It Works
1. Input & Configuration
  • Receives requests via webhook (rag-system)
  • Supports two actions:
    • upload → process documents
    • query → answer questions
  • Defines:
    • Chunk size & overlap
    • TopK retrieval count
    • Database table names
Document Upload Flow
  1. Text Extraction
    • Extracts text from uploaded PDF documents
  2. Text Chunking
    • Splits text into overlapping chunks for better retrieval accuracy
  3. Document Structuring
    • Converts chunks into structured documents
  4. Embedding Generation
    • Generates vector embeddings using OpenAI
  5. Vector Storage
    • Stores embeddings in PGVector (Postgres)
  6. Upload Logging
    • Logs document metadata (user, filename, timestamp)
  7. Response
    • Returns success message via webhook
Query Flow
  1. Cache Check
    • Checks if query result exists in cache (last 1 hour)
  2. Cache Routing
  • If cached → return cached response
  • If not → proceed to retrieval
Cache Hit Flow
  1. Format Cached Response
  • Standardizes cached output format
  1. Respond to User
  • Returns cached answer with cached: true
Cache Miss Flow
  1. Vector Retrieval
  • Retrieves top relevant document chunks from PGVector
  1. AI Answer Generation
  • Uses LLM with retrieved context
  • Generates accurate, context-based answer
  1. Cache Storage
  • Saves query + response in database for reuse
  1. Response
  • Returns generated answer with cached: false
Setup Instructions
  1. Webhook Setup
    • Configure endpoint (rag-system)
    • Send payload with:
      • action: upload / query
      • user_id
      • document or query
  2. OpenAI Setup
    • Add API credentials for:
      • Embeddings
      • Chat model
  3. Postgres + PGVector
    • Enable PGVector extension
    • Create tables:
      • documents
      • query_cache
      • upload_log
  4. Configure Parameters
    • Adjust:
      • Chunk size (e.g., 1000)
      • Overlap (e.g., 200)
      • TopK (e.g., 5)
  5. Optional Enhancements
    • Add authentication layer
    • Add multi-tenant filtering (user_id)
Use Cases
  • AI document search systems
  • Internal knowledge base assistants
  • Customer support knowledge retrieval
  • Legal or compliance document analysis
  • SaaS AI chat with custom data
Requirements
  • OpenAI API key
  • Postgres database with PGVector
  • n8n instance (cloud or self-hosted)
Key Features
  • Full RAG architecture (upload + query)
  • PDF document ingestion pipeline
  • Semantic search with vector embeddings
  • Context-aware AI responses
  • Query caching for performance optimization
  • Multi-user support via metadata filtering
  • Scalable and modular design
Summary
A complete RAG-based AI system that enables document ingestion, semantic search, and intelligent query answering. It combines vector databases, LLMs, and caching to deliver fast, accurate, and scalable AI-powered knowledge retrieval.
