📚 Auto-generate documentation for n8n workflows with GPT and Docsify
Created by: Eduard || eduard
Eduard
Last update 18 days ago
This workflow creates a documentation system for n8n instances using Docsify.js. It serves a dynamic documentation website that allows users to:
  • View an overview of all workflows in a tabular format
  • Filter workflows by tags
  • Access automatically generated documentation for each workflow
  • Edit documentation with a live Markdown preview
  • Visualize workflow structures using Mermaid.js diagrams
📺 Check out the short 2-min demonstration on LinkedIn. Don't forget to connect!
🔧 Key Components
  1. Main Documentation Portal
  • Serves a Docsify-powered website
  • Provides a navigation sidebar with workflow tags
  • Displays workflow status, creation date, and documentation links
  1. Documentation Generator
  • Uses GPT model to auto-generate workflow descriptions
  • Creates Mermaid.js diagrams of workflow structures
  • Maintains consistent documentation format
  1. Live Editor
  • Split-screen Markdown editor with preview
  • Real-time Mermaid diagram rendering
  • Save/Cancel functionality
⚙️ Technical Details
Environment Setup
  • Requires write access to the specified project directory
  • Uses environment variables for n8n instance URL configuration
  • Implements webhook endpoints for serving documentation
⚠️ Security Considerations
Note: The current implementation doesn't include authentication for editing. Consider adding authentication for production use.
Dependencies
  • Docsify.js for documentation rendering
  • Mermaid.js for workflow visualization
  • OpenAI GPT for documentation generation
🔍 Part of the n8n Observability Series
This workflow is part of a broader series focused on n8n instance observability. Check out these related workflows:
  1. Workflow Dashboard - Get comprehensive analytics of your n8n instance
  2. Visualize Your n8n Workflows with Mermaid.js - Create beautiful workflow visualizations
Each workflow in this series helps you better understand and manage your n8n automation ecosystem!
