AI-generated summary block for WordPress posts
Created by: Dataki || dataki
Dataki
Last update a year ago
What is this workflow?
This n8n template automates the process of adding an AI-generated summary at the top of your WordPress posts.
It retrieves, processes, and updates your posts dynamically, ensuring efficiency and flexibility without relying on a heavy WordPress plugin.
Example of AI Summary Section
How It Works
  1. Triggers → Runs on a scheduled interval or via a webhook when a new post is published.
  2. Retrieves posts → Fetches content from WordPress and converts HTML to Markdown for AI processing.
  3. AI Summary Generation → Uses OpenAI to create a concise summary.
  4. Post Update → Inserts the summary at the top of the post while keeping the original excerpt intact.
  5. Data Logging & Notifications → Saves processed posts to Google Sheets and notifies a Slack channel.
Why use this workflow?
No need for a WordPress plugin → Keeps your site lightweight.
Highly flexible → Easily connect with Google Sheets, Slack, or other services.
Customizable → Adapt AI prompts, formatting, and integrations to your needs.
Smart filtering → Ensures posts are not reprocessed unnecessarily.
💡 Check the detailed sticky notes for setup instructions and customization options!
