Stock market technical analysis with GPT-4o and TradingView for Telegram
Created by: Badr || b4dr
Badr
Last update 23 days ago
Overview: Transform Your Trading with AI-Driven Technical Analysis
The Stock Market Technical Analysis Bot is an advanced n8n workflow that brings professional-grade stock analysis to Telegram users. This powerful AI agent analyzes stock charts in real-time, providing detailed technical insights that would typically require expensive software or expert knowledge.
By combining artificial intelligence with technical analysis indicators, this bot delivers actionable trading insights directly to your Telegram chat, making sophisticated market analysis accessible to traders of all experience levels.
Key Features and Capabilities
Advanced Technical Analysis Tools
  • Japanese Candlestick Pattern Recognition: Automatically identifies bullish engulfing, doji, hammer patterns and more
  • MACD Indicator Analysis: Detects bullish/bearish crossovers and divergence signals
  • Volume Trend Analysis: Validates price movements with volume confirmation
  • Support & Resistance Level Identification: Pinpoints key price levels for potential reversals
  • Bollinger Bands & RSI Analysis: Measures volatility and overbought/oversold conditions
  • Real-Time TradingView Charts: Professional-quality charts with multiple indicators
AI-Powered Trading Assistant
  • Natural Language Interface: Interact with the bot using simple conversational commands
  • Context-Aware Responses: The bot remembers your previous interactions for more relevant analysis
  • GPT-4o Integration: Leverages advanced language models for detailed explanations
  • Actionable Trading Insights: Receive clear, jargon-free analysis with practical implications
Technical Implementation
  • Telegram Bot Integration: Seamless messaging experience with instant responses
  • n8n Workflow Automation: No-code solution for complex trading analysis
  • Memory System: Maintains conversation context for personalized interactions
  • API Connections: Integrates with TradingView, chart-img.com, and OpenAI
Setup Instructions
Prerequisites
  1. n8n Instance: A running n8n installation with the following nodes:
    • Telegram nodes
    • LangChain nodes
    • HTTP Request nodes
    • Code node
  2. Required API Credentials:
    • Telegram Bot API token (obtain from @BotFather)
    • OpenAI API key
    • Chart-img.com API key
Installation Process
  1. Import the workflow template into your n8n instance
  2. Configure your Telegram bot credentials
  3. Set up your OpenAI API credentials
  4. Enter your chart-img.com API key in the HTTP Request node
  5. Activate the workflow to start receiving analysis requests
How It Works: The Technical Analysis Process
1. User Interaction Flow
When a user sends a message to the Telegram bot:
  • The Telegram Trigger node captures the incoming message
  • The AI Agent processes the request using natural language understanding
  • If a stock symbol is detected, the GetChart tool is invoked
2. Chart Generation System
The workflow creates professional TradingView charts with:
  • Candlestick price data
  • Bollinger Bands for volatility measurement
  • Volume indicators for trade validation
  • RSI (Relative Strength Index) for momentum analysis
3. AI Analysis Engine
The GPT-4o model analyzes the chart and provides:
  • Detailed breakdown of candlestick patterns
  • MACD trend confirmation signals
  • Volume analysis to validate price movements
  • Support and resistance level identification
  • Overall market sentiment assessment
4. Response Delivery
The analysis is formatted and sent back to the user via Telegram, including:
  • The generated chart image
  • Comprehensive technical analysis text
  • Actionable insights based on the indicators
Use Cases and Applications
For Day Traders
  • Receive quick technical analysis before making trading decisions
  • Validate your own analysis with AI-generated insights
  • Track multiple stocks efficiently throughout the trading day
For Swing Traders
  • Analyze medium-term trends and potential entry/exit points
  • Identify key support and resistance levels for stop-loss placement
  • Get objective analysis to complement your trading strategy
For Trading Communities
  • Share consistent, AI-generated analysis among group members
  • Create a common analytical framework for discussion
  • Reduce the learning curve for technical analysis concepts
For Financial Educators
  • Demonstrate technical analysis concepts with real-time examples
  • Provide students with accessible tools for practice
  • Illustrate the application of various technical indicators
Advanced Configuration Options
The workflow can be customized to:
  • Add additional technical indicators (Fibonacci retracements, Moving Averages, etc.)
  • Modify the analysis parameters for different trading styles
  • Integrate with other financial data sources for fundamental analysis
  • Connect to different messaging platforms beyond Telegram
  • Create scheduled analysis for watchlist stocks
Troubleshooting Common Issues
If you encounter problems:
  1. Authentication Errors: Verify all API credentials are correctly configured
  2. Telegram Connection Issues: Ensure your Telegram bot is properly set up
  3. Chart Generation Failures: Check your chart-img.com API key and quota
  4. Slow Response Times: Consider upgrading your OpenAI plan for faster processing
  5. Missing Indicators: Verify the chart configuration in the HTTP Request node
About This Template
This n8n workflow template demonstrates the power of combining conversational AI with technical analysis tools to create a sophisticated financial assistant. It showcases advanced workflow automation features including AI integration, external API connections, and complex data processing.
By leveraging the latest advancements in AI and technical analysis, this template provides traders with professional-grade insights without requiring expensive software or deep technical expertise.
Keywords: stock market analysis bot, AI trading assistant, technical analysis indicators, n8n workflow, Telegram trading bot, candlestick pattern recognition, MACD analysis, trading signals, automated stock analysis, GPT-4o financial analysis, TradingView charts, RSI indicator, volume analysis, support resistance levels, day trading bot, swing trading analysis, AI financial advisor
