Create and join call sessions with Plivo and UltraVox AI Voice Assistant
Created by: Yohita || yohita
Yohita
Last update a month ago
This workflow template creates an audio stream session on UltraVox compatible with Plivo and sends it to Plivo.
How It Works :
Plivo initiates a call and requests the Answer URL.
The workflow responds with Plivo XML to join the session.
Note:
Ensure you update the UltraVox API Key in the credentials.
Update System Prompt based on your requirements.
Check Youtube Video
Youtube Video
