Scrape Trustpilot reviews using Bright Data & GPT-5.4 for winning ad copy
Yaron Been
Last update 3 days ago
🔍 Competitor Review Scraper & Ad Copy Generator
(Trustpilot + Bright Data + GPT-5.4)
📌 Who It's For
Marketers, business owners, and agencies looking to:
  • Analyze competitor pain points
  • Generate high-impact Facebook ad copy
  • Automate manual data processing
🧩 How It Works
This n8n-based workflow combines Bright Data, Google Sheets, and OpenAI to scrape, process, and transform Trustpilot reviews into ready-to-use ad copy.
🔹 Step-by-Step Breakdown
  1. Trigger (Manual Form Submission)
    Input required:
Competitor’s Trustpilot URL
Review timeframe (30d, 3m, 6m, 12m)
  1. Fetch Reviews
Calls Bright Data’s Dataset API with URL & timeframe
Polls until snapshot is ready
  1. Retrieve & Store
Extracts all reviews
Saves them into a structured Google Sheet
  1. Filter & Aggregate
Filters to only 1–2 star reviews
Summarizes common negative feedback
  1. Generate Ad Copy
Sends the summary to OpenAI GPT-5.4
Produces 3 variations of ad copy targeting pain points
  1. Distribute Insights
Sends ad copy + summary via email to the marketing team
✅ Requirements
-LLM Account
-Google Sheets - Copy this sheet:
https://docs.google.com/spreadsheets/d/1Zi758ds2_aWzvbDYqwuGiQNaurLgs-leS9wjLWWlbUU/edit?gid=0#gid=0
-Bright Data account
⚙️ Setup Instructions
**Step 1: Google Sheets
Copy this Google Sheets template
Do not change column headers
**Step 2: n8n Credential Setup
Google Sheets: OAuth2
Bright Data: Authorization Header
OpenAI: API Key for GPT-5,4
**Step 3: Import Workflow
Import the .json file into n8n
Configure your sheet + dataset ID
Adjust GPT prompts as needed
**Step 4: Run the Workflow
Trigger via form
Receive ad copy + review insights via email
🧠 Tips & Best Practices
  • Bright Data snapshots may take time — polling is handled
  • Focusing on 1–2 star reviews yields the most actionable pain points
  • You can customize GPT-5.4 prompts for tone or vertical
💬 Support & Feedback
Need help or customization?
📧 Email: [email protected]
📺 YouTube: @YaronBeen
🔗 LinkedIn: linkedin.com/in/yaronbeen
📚 Bright Data Docs: docs.brightdata.com/introduction
