Telegram bot for item multi select and saving to Postgres (Module "Checkbox")
Who is this for?
This template is for developers and automation specialists looking to create a Telegram bot that enables users to select items from a predefined list and save their choices to a Postgres database.
What problem is this workflow solving?
It provides a simple and efficient way to collect structured user input via Telegram and store it in a Postgres database, useful for inventory selection, order systems, or preference tracking.
What this workflow does
  • Displays a list of selectable options from a Postgres shop_list table in Telegram
  • Saves the user’s selection back to the database
  • Automatically deletes messages at each step to keep the chat clean
1. Create the required tables in Postgres
  • Replace "n8n" in the provided SQL script with the appropriate schema name for your database
  • Run the script to create the shop_list table
2. Add necessary credentials in n8n
  • Telegram: Connect your Telegram bot using the Bot Token
  • Postgres: Add your Postgres DB credentials to allow the workflow to read/write data
How to customize this workflow to your needs
  • Modify the shop_list table to include your specific options.
  • Adjust the Telegram messages and logic to match your use case.
