Collect LinkedIn profiles with AI processing using SerpAPI, OpenAI, and NocoDB
Created by: Askan || askans
Askan
Last update 8 months ago
Categories
What problem does this solve?
It fetches LinkedIn profiles for a multitude of purposes based on a keyword and location via Google search and stores them in an Excel file for download and in a NocoDB database.
It tries to avoid using costly services and should be n8n beginner friendly.
It uses the serpapi.com to avoid being blocked by Google Search and to process the data in an easier way.
What does it do?
  • Based on criteria input, it searches LinkedIn profiles
  • It discards unnecessary data and turns the follower count into a real number
  • The output is provided as an Excel table for download and in a NocoDB database
How does it do it?
  • Based on criteria input, it uses serpAPI.com to conduct Google search of the respective LinkedI profiles
  • With OpenAI.com the name of the respective company is being added
  • With OpenAI.com the follower number e.g., 300+ is turned into a real number: 300
  • All unnecessary metadata is being discarded
  • As an output an Excel file is being created
  • The output is stored in a nocodb.com table
Step-by-step instruction
  1. Import the Workflow:
    Copy the workflow JSON from the "Template Code" section below.
    Import it into n8n via "Import from File" or "Import from URL".
  2. Set up a free account at serpapi.com and get API credentials to enable good Google search results
  3. Set up an API account at openai.com and get API key
  4. Set up a nocodb.com account (or self-host) and get the API credentials
  5. Create the credentials for serpapi.com, opemnai.com and nocodb.com in n8n.
  6. Set up a table in NocoDB with the fields indicated in the note above the NocoDB node
  7. Follow the instructions as detailed in the notes above individual nodes
  8. When the workflow is finished, open the Excel node and click download if you need the Excel file
