Automatic jest test generation for GitHub PRs with dual AI review
Created by: Varritech || varritech
Varritech
Last update 17 days ago
Workflow: Automatic Unit Test Creator from GitHub
🏗️ Architecture Overview
This workflow listens for GitHub pull-request events, analyzes changed React/TypeScript files, auto-generates Jest tests via AI, has them reviewed by a second AI pass, and posts suggestions back as PR comments:
  1. GitHub Webhook → PR opened or updated
  2. Fetch & Diff → Retrieve raw diff of changed files
  3. Filter & Split → Isolate .tsx files & their diffs
  4. Fetch File Contents → Provide full context for tests
  5. Test Maker Agent → Generate Jest tests for diff hunks
  6. Code Reviewer Agent → Refine tests for style & edge-cases
  7. Post PR Comment → Sends suggested tests back to GitHub
📦 Node-by-Node Breakdown
flowchart LR
  A[Webhook: /github/pr-events] --> B[GitHub: Get PR]
  B --> C[Function: Parse diff_url + owner/repo]
  C --> D[HTTP Request: GET diff_url]
  D --> E[Function: Split on "diff --git"]
  E --> F[Filter: /\.tsx$/]
  F --> G[GitHub: Get File Contents]
  G --> H[Test Maker Agent]
  H --> I[Code Reviewer Agent]
  I --> J[Function: Build Comment Payload]
  J --> K[HTTP Request: POST to PR Comments]
Webhook: GitHub PR Events
  • Type: HTTP Webhook (/webhook/github/pr-events)
  • Subscribed Events: pull_request.opened, pull_request.synchronize
GitHub: Get PR
  • Node: GitHub
  • Action: "Get Pull Request"
  • Inputs: owner, repo, pull_number
  • Extracts:
    • diff_url (e.g. …/pulls/123.diff)
    • owner, repo, merge_commit_sha
  • Fetches unified-diff text for the PR.
  • Splits the diff into file-specific segments.
Filter: /.tsx$/
  • Keeps only segments where the file path ends with .tsx.
  • For each .tsx file, fetches the latest blob via GitHub API.
Test Maker Agent
  • Prompt:
    • "Generate Jest unit tests covering only the behaviors changed in these diff hunks."
  • Output: Raw Jest test code.
Code Reviewer Agent
  • Reads file + generated tests
  • Prompt:
    • "Review and improve these tests for readability, edge-cases, and naming conventions."
  • Output: Polished test suite.
  • Wraps tests in TypeScript fences:
// generated tests…
  • Constructs JSON:
{ "body": "<tests>" }
  • URL: https://api.github.com/repos/{owner}/{repo}/issues/{pull_number}/comments
  • Body: Contains the suggested tests.
🔍 Design Rationale & Best Practices
Focused Diff Analysis
  • Targets only .tsx files to cover UI logic.
Two-Stage AI
  • Separate "generate" + "review" steps mimic TDD + code review.
Stateless Functions
  • Pure JS for parsing & transformation, easy to test.
Non-Blocking PR Comments
  • Asynchronous suggestions—developers aren't blocked.
Scoped Permissions
  • GitHub token limited to reading PRs & posting comments.
