AI chatbot call center: General exception flow (production-ready, part 8)
Created by: ChatPayLabs || chatpaylabs
ChatPayLabs
Last update 23 days ago
Categories
Workflow Name: 👻 Exception Flow
Template was created in n8n v1.90.2
Skill Level: Low
Categories: n8n, Chatbot
Stacks
  • Error Trigger
  • Slack node
What this workflow does?
This is a n8n Error Workflow. It will trigger when there is an error in another workflow. When this happens, it then tries to send an error notification to the preset Slack channel.
  • The Error Trigger node will trigger when there is an error in another workflow, as long as that workflow is set up to do so.
  • A error notification will be sent to the Slack Channel.
Set up instructions
  1. Create you Slack credentials, refer to n8n integration documentation for more information.
  2. Set up the Channel in 👻 Exception Alert node.
  3. For any n8n workflows to trigger this, switch to that workflow, select menu > settings, and set the Error Workflow to 👻 Exception Flow.
How to adjust it to your needs
Although this workflow template is part of the AI Chatbot Call Center Series, it could be used with any n8n workflows.
  • Update the Channel in 👻 Exception Alert to your own channel
https://chatpaylabs.com/blog/part-8-build-your-own-ai-chatbot-call-center-general-exception-flow-production-ready-n8n-workflow-free-download-
