Generate images and convert to video using Flux, Kraken & Runway
Created by: Joseph || mjomba
Joseph
Last update 16 days ago
(Image Generation → Hosting → Video Generation)
This workflow is designed for creators, automation enthusiasts, and indie hackers who want to generate image-based videos automatically using AI tools — at a low cost.
⚙️ Workflow Overview
This automation performs the following steps:
  1. Trigger (Schedule or manual)
  2. Generate an image using Flux (choose between two APIs)
  3. Upload the image to Kraken.io to get a public URL
  4. Send the image to Runway ML (choose between two APIs) to generate a video
  5. Receive the video as a URL — ready for posting, download, or further automation
🛠️ Step-by-Step Setup
🖼️ Flux (Image Generation)
You can use either of the following providers:
Option 1: Flux by BlackForest Labs (Direct API)
🔑 Get your API key here: https://docs.bfl.ml/
  • Paste your API key in the HTTP Request node named Flux (Blackforest)
  • You can customize prompts or styles inside the JSON body
Option 2: Flux via RapidAPI
🔑 Subscribe and get your key here:
https://rapidapi.com/poorav925/api/ai-text-to-image-generator-flux-free-api/playground/apiendpoint_e38039ee-1912-4ef9-b4d4-270d72fca851
  • Enter your RapidAPI key in the X-RapidAPI-Key header
  • Optional: tweak prompts, style, or resolution inside the JSON body
🐙 Kraken.io (Hosting the Image Publicly)
Runway ML requires the image to be publicly accessible. We use Kraken.io to host the generated image and return a public URL.
🔑 Get your API credentials: https://kraken.io/account/api-credentials
Setup:
  1. Copy your API Key and API Secret
  2. Open the Kraken Upload node in n8n
  3. Replace placeholders with your credentials
  4. The node uploads your image and gives back a public image URL for Runway to use
🎬 RunwayML (Video Generation)
You also have two options here:
Option 1: Runway Official API
🔑 Get your credentials at: https://dev.runwayml.com/
  • Use the public image URL from Kraken in the JSON body
  • Paste your Bearer token in the Authorization header
  • Customize other settings like video length, style, FPS, etc.
Option 2: Runway via RapidAPI
https://rapidapi.com/fortunehoppers/api/runwayml/playground/apiendpoint_93c8554d-8097-40cd-8252-3d4dec9c0e68
  • Paste your RapidAPI key in the request header
  • Customize prompt and generation options in the body
  • Use the Kraken-generated image URL as the input source
📤 What to Do with the Video
Once the video is generated, you’ll get a direct video URL. You can:
  • Save it to Google Sheets or Notion
  • Send it via email
  • Trigger a YouTube upload automation
  • Or download manually for editing and reposting
💡 Optional Tips & Notes
  • You can schedule this workflow to generate AI videos daily or weekly
  • Combine it with a Google Sheet of prompts for bulk automation
  • Try using a consistent visual style or theme for better branding
  • This workflow is lightweight and affordable — perfect for indie projects or experimental content generation
  • Great for shorts, quote visuals, music loops, AI art promos, etc.
🔗 Resources
🙋 Need Help?
Feel free to reach out:
If you’d like to hire me for custom n8n workflows or product automations, don’t hesitate to get in touch.
