Evaluation metric example: Check if tool was called
Created by: David Roberts || davidn8n
David Roberts
Last update 15 days ago
AI evaluation in n8n
This is a template for n8n's evaluation feature.
Evaluation is a technique for getting confidence that your AI workflow performs reliably, by running a test dataset containing different inputs through the workflow.
By calculating a metric (score) for each input, you can see where the workflow is performing well and where it isn't.
This template shows how to calculate a workflow evaluation metric: whether a specific tool was called by an agent.
  • We use an evaluation trigger to read in our dataset
  • It is wired up in parallel with the regular trigger so that the workflow can be started from either one. More info
  • We make sure that the agent outputs the list of tools that it used
  • We then check whether the expected tool (from the dataset) is in that list
  • Finally we pass this information back to n8n as a metric
