TrustPilot SaaS product review tracker with Bright Data & OpenAI
Created by: Ranjan Dailata || ranjancse
Ranjan Dailata
Last update 15 days ago
Who this is for
The TrustPilot SaaS Product Review Tracker is designed for product managers, SaaS growth teams, customer experience analysts, and marketing teams who need to extract, summarize, and analyze customer feedback at scale from TrustPilot.
This workflow is tailored for:
  • Product Managers - Monitoring feedback to drive feature improvements
  • Customer Support & CX Teams - Identifying sentiment trends or recurring issues
  • Marketing & Growth Teams - Leveraging testimonials and market perception
  • Data Analysts - Tracking competitor reviews and benchmarking
  • Founders & Executives - Wanting aggregated insights into customer satisfaction
What problem is this workflow solving?
Manually monitoring, extracting, and summarizing TrustPilot reviews is time-consuming, fragmented, and hard to scale across multiple SaaS products.
This workflow automates that process from unlocking the data behind anti-bot layers to summarizing and storing customer insights enabling teams to respond faster, spot trends, and make data-backed product decisions.
This workflow solves:
  • The challenge of scraping protected review data (using Bright Data Web Unlocker)
  • The need for structured insights from unstructured review content
  • The lack of automated delivery to storage and alerting systems like Google Sheets or webhooks
What this workflow does
Extract TrustPilot Reviews: Uses Bright Data Web Unlocker to bypass anti-bot protections and pull markdown-based content from product review pages
Convert Markdown to Text: Leverages a basic LLM chain to clean and convert scraped markdown into plain text
Structured Information Extraction: Uses OpenAI GPT-4o via the Information Extractor node to extract fields like product name, review date, rating, and reviewer sentiment
Summarization Chain: Generates concise summaries of overall review sentiment and themes using OpenAI
Merge & Aggregate Output: Consolidates individual extracted records into a structured batch output
Outbound Data Delivery:
  • Google Sheets – Appends summary and structured review data
  • Write to Disk – Persists raw and processed content locally
  • Webhook Notification – Sends a real-time alert with summarized insights
Pre-conditions
  1. You need to have a Bright Data account and do the necessary setup as mentioned in the "Setup" section below.
  2. You need to have an OpenAI Account.
  • Sign up at Bright Data.
  • Navigate to Proxies & Scraping and create a new Web Unlocker zone by selecting Web Unlocker API under Scraping Solutions.
  • In n8n, configure the Header Auth account under Credentials (Generic Auth Type: Header Authentication).
    The Value field should be set with the
    Bearer XXXXXXXXXXXXXX. The XXXXXXXXXXXXXX should be replaced by the Web Unlocker Token.
  • In n8n, Configure the Google Sheet Credentials with your own account. Follow this documentation - Set Google Sheet Credential
  • In n8n, configure the OpenAi account credentials.
  • Ensure the URL and Bright Data zone name are correctly set in the Set URL, Filename and Bright Data Zone node.
  • Set the desired local path in the Write a file to disk node to save the responses.
How to customize this workflow to your needs
Target Multiple Products :
  • Configure the Bright Data input URL dynamically for different SaaS product TrustPilot URLs
  • Loop through a product list and run parallel jobs for each
Customize Extraction Fields :
Update the prompt in the Information Extractor to include:
  • Review title
  • Response from company
  • Specific feature mentions
  • Competitor references
Tune Summarization Style
  • Change tone: executive summary, customer pain-point focus, or marketing quote extract
  • Enable sentiment aggregation (e.g., 30% negative, 50% neutral, 20% positive)
Expand Output Destinations
  • Push to Notion, Airtable, or CRM tools using additional webhook nodes
  • Generate and send PDF reports (via PDFKit or HTML-to-PDF nodes)
  • Schedule summary digests via Gmail or Slack
