Bulk AI Image Generator, Rename Engine & 4× Upscaler
Created by: victor Adriano || bwire
victor Adriano
Last update a month ago
YOUTUBE GUIDE
📣 This template generates up to 2,000 AI-based stock images per day for under $4. It includes prompt generation, image creation, metadata enrichment, upload to Google Drive, and error logging — fully automated with minimal setup.
📌 Who is this for?
This workflow is designed for:
  • Stock image creators and contributors
  • Agencies managing visual content at scale
  • Solo creators or marketers automating asset production
  • Anyone aiming to populate image libraries (e.g., Adobe Stock, Shutterstock)
What problem is this workflow solving?
Manually generating, naming, tagging, and uploading thousands of stock images is time-consuming and expensive. This automation solves that by:
  • Generating photorealistic images via AI
  • Auto-tagging with rich metadata
  • Uploading them to structured Google Drive folders
  • Logging progress and capturing errors automatically
⚙️ What this workflow does
  • ✅ Generates text prompts from idea topics using GPT
  • 🎨 Converts prompts into 4 images each via the Flux Schnell model
  • 📐 Resizes and compresses images for preview and final use
  • 🧠 Uses GPT-4o-mini to generate metadata: filename, title, category, and 25 keywords
  • ☁️ Uploads to Google Drive, logs metadata to Google Sheets
  • 🟢 Marks each prompt as completed
  • 📲 Sends Telegram alerts for success and errors
🛠 Setup
  1. Google Sheets
    • Sheet 1: IdeasNew prompt topics
    • Sheet 2: Generated PmtsTracks generated prompts and status
    • Sheet 3: Error LogsExecution error records
  2. Google Drive
    • A folder for image uploads
    • A folder for copied daily spreadsheets
  3. API Access
    • OpenAI GPT (gpt-4o-mini)
    • PIAPI (Flux Schnell image model)
  4. Telegram Bot (optional but recommended)
    • Real-time status notifications
🧩 How to customize this workflow to your needs
  • 🔁 Change frequency of generation via trigger settings
  • 🧠 Swap models if using a different image API
  • 🧾 Adjust metadata fields or format rules
  • 📤 Redirect outputs to Airtable, Notion, Dropbox, etc.
🗂️ Categories
  • AI
  • Marketing
  • Product
  • Building Blocks
🎁 Bonus Feature
This template includes a bonus stock image renamer workflow — ideal for renaming:
  • 📸 Taken photos
  • 🗃️ Existing stock libraries
  • 🖼️ Downloaded image batches
It applies SEO-friendly, consistent naming compatible with major platforms like Adobe Stock and Shutterstock.
